10-17-2013 04:05 PM - edited 03-16-2019 07:57 PM
I am not dedicated voice guy but got task to remove server from Disaster Recovery System Scheduler because it keeps sending alert email as below:
Backup process failed. Investigate sftp server settings. Reason : DRF was unable to backup component PLATFORM.Error : Host [CMSUB2] has disconnected during backup AppID : Cisco DRF Master ClusterID :
NodeID : CMPUB1
TimeStamp : Thu Oct 17 03:44:42 PDT 2013.
The alarm is generated on Thu Oct 17 03:44:42 PDT 2013.
We just shudown the backup CUCM (CMSUB2) so that's why the mail started sending out.
Could you kindly advise how I can remove the shutdown CUCM from Scheduler of DRS registerred server so that it won't keep sending out backup error email ?
CUCM verison 8.5.1
Thanks a lot !
Solved! Go to Solution.
10-18-2013 06:00 AM
Hi Scott,
You will continue to get these errors unless the CMSUB2 is deleted
from the CUCM db and then the cluster is rebooted
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/8_5_1/ccmcfg/b02servr.html#wpxref82891
Cheers!
Rob
"Why do the best things always disappear "
- The Band
10-18-2013 06:00 AM
Hi Scott,
Cheers!
Rob
- The Band
10-18-2013 10:52 AM
Rob,
Thanks for advices.
10-18-2013 11:45 AM
Hi Rob,
Do I need to reboot both CUCM (Master and Cluster) or just reboot the cluster one ?
Thanks in advance,
10-18-2013 12:16 PM
Hi Scott,
The cluster = all servers (Pub & Sub(s))
Cheers!
Rob
- The Band
10-18-2013 03:02 PM
Thanks for bearing mine stupid question.
11-04-2013 10:26 AM
Hi Rob,
Another question, which service I need restart after removing none-used server. The "Cisco CallManager" in CM Service ?
Snce in Cisco Unified Serviceability --> Control Center --> Feature Services, I am seeing there are many running services.
Just need restart the one "Cisco CallManager" or also need restart others.
Thank you,
11-04-2013 10:39 AM
Hi Scott,
In this case you would need to restart the whole server rather
than just a sub-set of services
from cli;
utils system restart
Can be done via gui as well.
Cisco Unified OS Admin" page, select "Settings" > version > restart
Cheers!
Rob
- The Band
11-04-2013 10:50 AM
Hi Rob,
Thank you,
Scott
