Unregistered Phone Report
iverson.justin
Is there an easy way to export of list of phones that have never been registered to CUCM?  Running short on licenses and need to remove devices that have never been online.
jonathan.salter
Level 3
Level 3
So when you go to your device page look for the ones that don't have an IP address populated, that may be one way. I believe you can use the show risdb command from CLI to find last registered devices.
Please remember to rate useful posts, click on the stars below.
Jaime Valencia
If you're running 12.x you can look at the last registered column under device search, if there's no date, the device has never registered.
On previous releases you'd need to run some CDR/CAR reports to find out which devices are active and placing calls, and then weed out those that aren't.
java
if this helps, please rate
jonathan.salter
Level 3
Level 3
