08-17-2018 04:27 PM - edited 03-17-2019 01:22 PM
Hi all,
I have users (about 21) in new location that I need to add to CUCM 11.5.
All the users are in LDAP. I also got new DID numbers.
The users/phones are in different location then I.
I would like to know the easy and simple way to add users/phones to CUCM.
I am thinking of creating phones/users template in Bulk Administration and then export the files, I luck the experience and would like some help to achieve that.
Solved! Go to Solution.
08-17-2018 05:23 PM
You can use BAT for both, for users if they're local users.
You can simply do an export and use it as a sample.
You can do self-provisioning, or just auto-registration and then manually adjust the settings as required.
Or you can do it manually per device.
08-17-2018 05:23 PM
08-20-2018 03:48 PM
Did it manually and was easy. Thanks for Quick reply Jaime
