02-20-2012 09:33 AM - edited 03-16-2019 09:40 AM
Hi what are he steps to configure an already configured call manger express to call manager 8
02-20-2012 09:38 AM
You'll need to elaborate, do you want to call between the systems?? plenty of posts on that, just configure CME as H323 in CUCM and the necessary VoIP dial-peers in CME.
Upgrade?? there's really no upgrade path between this systems. No tools to get the info from one to another.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
02-20-2012 09:49 AM
Right, if you just want to upgrade CME then upgrade the IOS to desired version and replace all files, i.e. GUI, firmware, etc.
HTH,
Chris
02-20-2012 09:56 AM
Currenly they have Cme router With 100 users they ask me is it possible to upgrade it as Callmanager unified Version 8 with unity connection ....is there is any method to transfer files from cme Router to Mcs Server
02-20-2012 09:57 AM
No, you have to build it from scratch. There is no conversion of any kind. Sorry.
HTH,
Chris
02-20-2012 09:59 AM
No, as I've already mentioned, there's no upgrade path nor method to get data from one to the other.
With just 100 users you can use auto-registration to get the phones configured with basic settings or use BAT.
The rest of the config you'll need to redo in CUCM.
java
02-20-2012 10:01 AM
So you mean i need to install same like a fresh installation ...
02-20-2012 10:03 AM
Yes, not to mention one runs on ISRs and the other one on MCS/UCS so they're completely different platforms and architectures.
java
02-20-2012 10:09 AM
Ok .Thankz ..what if i congured all in ucs server same like a new configuration ...whther it make any conflicts between cme config and ucs config
02-20-2012 10:55 AM
Shabeel,
I strongly suggest you hire a professional as this is not something you can just slap in without serious implications down the line, if you have never built such a deployment you are asking for trouble trying this on your own.
Chris
