Upgrade Call Manager Software 7.1.5.10000-12
j.laible
We are currently on Call Manager version 7.1.5.10000-12 running on specs below. Can someone helo us understand what version we can upgrade to? And also how difficult it is? Where can we start?
As you can tell we are new to this so any insight would be much appreciated:
admin:show hardware
HW Platform       : 7828I4
Processors        : 1
Type              : Intel(R) Core(TM)2 Quad CPU    Q9400  @ 2.66GHz
CPU Speed         : 2660
Memory            : 8192 MBytes
Object ID         : 1.3.6.1.4.1.9.1.899
OS Version        : UCOS 4.0.0.0-33
RAID Version      :
Raid firmware version: 1.26.81.00
Raid Bios version: 6.16.00.00
BIOS Information  :
IBM IBMBIOSVersion1.44-[M9E144AUS-1.44]- 06/11/2009
RAID Details      :
LSI Logic IR Configuration Utility 2.00.15
Read configuration has been initiated for controller 0
6 Replies 6
Aman Soi
Hi Jim,
Are u using BE since this is BE appliance ?
can u share the show version active output from CLI using putty.
regds,
aman
I'm not sure what BE is. This is the applianc e where Call Manager is installed.
admin:show version active
Active Master Version: 7.1.5.10000-12
Active Version Installed Software Options:
cmterm-69xx-sccp.9-0-3-a.cop
cmterm-69xx-sccp.9-0-3-b.cop
cmterm-69xx-sccp.9-1-1-sr1.cop
cmterm-7945_7965-sccp.9-0-3.cop
cmterm-7942_7962-sccp.9-0-3.cop
Hi Jim ,
It is BE 5000.
You can upgrade CUCM to 9.0(x) and 9.1(x).Please refer the link
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6790/ps5748/ps378/prod_brochure0900aecd8062a4f9.html
u can follow the upgrade path 7.1(5 )------> 8.5(1) Unrestricted-------> 8.6.2.21900-5 Unrestricted ------->  9.1.1.20000-5 Unrestricted
Also, cop files would be required.
I would suggest to speak to Cisco SE since I have never upgraded the BE.
regds,
aman
Looking through our contract info, it's actually model MCS7828I4-K9-WL which I don't see in your link. Thanks for the info.
If we get the correct version of upgrade files and upgrade path, is it as simple as this video shows?
http://www.youtube.com/watch?v=REHtMvz_oJQ
Just looking for gotchas and things to typically look out for when upgrading.
Hi Jim,
I think this server comes with default of 50 CUWL licenses.
regds,
aman
