upgrade CCM 6.1 to 8.6 P2V, old models 7985
carlos.collart
some of our board directors had Cisco OLD EoL IP Phones 7985 as desktop phones,
the surprise today 2 weeks after an upgrade implementation was that the old 7985, doesn't support IP Array in the DCHP option 150.
ip dhcp pool IP_Telephony
       option 150 ip xx.xxx.x.xx xx.xxx.x.xx
the IP Phones show on the screen TFTP Quering xxx.xxx.xxx
our solution was move the phones to the data vlan and use only 1 IP in the option 150 for that scope.
cmterm_7985.4-1-7-0
acampbell
Carlos,
You are hitting a software bug for 7985 - 4-1-7
CSCtf78637 Bug Details
7985 stuck "querying TFTP server"
Symptom:
After downloading the 4.1(7) firmware, the 7985 stays stuck in "querying TFTP server"
Conditions:
There are two TFTP servers defined
Workaround:
Remove one of the TFTP servers
There is no fix from Cisco as yet.
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
