Upgrade CUCM 7.1.3 to 7.1.5
adapozzo79
Hi All,
i have a standalone server with the following configuration:
System version: 7.1.3.20000-2
Locale:               cm-locale-it_IT-7.1.3.2000-1.cop
Devpkg:             cmterm-devicepack7.1.3.33031-1.cop
Platform type:    MCS7816I-K9-CMC2
I want upgrade to version 7.1.5 , can i use the lastest 7.1(5b)SU4 or is better another version?
I see these two guides :
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6790/ps5748/ps378/prod_brochure0900aecd8062a4f9.html
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/compat/ccmcompmatr.html
but is not clear for me what is the best way.
6 Replies 6
Rob Huffman
Hi Andrea,
Yes, you can go directly to 7.1(5b)SU4;
Direct upgrade:7.1(5b)SU
7.1(5b)SU3(restricted),
7.1(5b)SU2(restricted), 7.1(5b)(restricted), 7.1(5a)(restricted), 7.1(5)SU1a(restricted), 7.1(5)SU1(restricted), 7.1(5)(restricted), 7.1(3b)SU2, 7.1(3b)SU1, 7.1(3b), 7.1(3a)SU1a, 7.1(3a)SU1, 7.1(3a), 7.1(3), 7.1(2b)SU1, 7.1(2b), 7.1(2a) SU1, 7.1(2a), 7.1(2), 7.0(2a)SU3, 7.0(2a)SU2, 7.0(2a)SU1, 7.0(2a), 7.0(2), 6.1(5)SU3, 6.1(5)SU2, 6.1(5)SU1, 6.1(5), 6.1(4a)SU2, 6.1(4a), 6.1(4)SU1, 6.1(4), 6.1(3b)SU1, 6.1(3b), 6.1(3a), 6.1(3), 5.1(3g), 5.1(3f), 5.1(3e)1 5.1(3d), 5.1(3c), 5.1(3b), 5.1(3a), 5.1(3)
This version will have the most bug fixes and should be the most stable
Cheers!
Rob
Please remember to tag your threads and help support "Teachers without Borders"
https://supportforums.cisco.com/community/netpro/idea-center/communityhelpingcommunity
I am having the same situation with a cluster over WAN.
Any special considerations.
Hi Yahya,
I confirm that the upgrade worked without any problems
Thanks Andrea,
So each server to do the upgrade for individually then restart or switch version on each statrting by PUB?
Simsam
I simply made ​​a backup on external drive before starting and after that I followed the instructions of following official guide:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/rel_notes/7_1_5/cucm-rel_notes-715b.pdf
