05-10-2013 07:45 AM - edited 03-16-2019 05:15 PM
i have CUCM version 7.1.3 run under secure mode and i need to upgrade to 7.1.5 to integrate with IPhones and andriod phones Jabber
client, and i need to know Cisco recommendation and detailed steps for this upgrade ,
thanks ....
05-10-2013 09:57 AM
You're likely running under mixed mode, correct? Secure-only mode doesn't exist, at least not publicly, to my knowledge.
The upgrade doesn't differ really: you install the L2 upgrade and the services come back up with their existing certificates. The existing CTL file remains intact. Follow the upgrade guide as always and validate that none of your certificates (CAPF, CUCM+TFTP, etc) have expired prior to starting the upgrade. Have a backup and a rollback plan just in case.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/cucos/7_1_2/cucos/iptpch7.html
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/security/7_1_2/secugd/sec712-cm.html
Please remember to rate helpful responses and identify helpful or correct answers.
05-11-2013 08:05 AM
Thank you for your help,
And yes it in mixed mode, and I get from you that it will be normal upgrade steps , right ?
But is there any recommendation from Cisco about this ?
