03-18-2012 01:37 AM - edited 03-16-2019 10:11 AM
Dear cisco team i need to uprade cisco unity 5 to unity 8. i have the BOM for existing Unity which is 5 and i need to ugprade it to latest version because
i am going to upgrade call manager to 8.5. i need to know below things.
1- Is Cisco unity 5 can work with cisco unified communication manager 8.5?
2-If i need to upgrade unity 5 to version 8 based on the below hardwaer can i use the same hardware to upgrade or i need to upgrade hardware or replace hardware i need to know these things.
Below is the BOM for unity 5.0
UNITY-5.X-K9 | Unity VM, 100 users (w/ 16 sessions) | 1 | ||||||||
UNITYV5-100USR | Unity VM, 100 users (w/ 16 sessions) | 1 | ||||||||
UNITY5.X-EXCH-KIT | Message Store 2003 | 1 | ||||||||
MCS-7816-I4-IPC1 | HW Only MCS 7816-I4 Server | 1 |
03-18-2012 06:41 AM
Hi Jamil,
Unity 5.0 is fully supported with CUCM 8.5 (check Table 1)
Supported Version Combinations for Cisco Unity, the Cisco Unity-CM TSP, and Cisco Unified Communications Manager
From this compatability Matrix;
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/compatibility/matrix/cutspmtx.html#wp51076
I don't see your server model in the "supported" list for Unity 8.x
Cheers!
Rob
03-18-2012 07:47 AM
Thanks rob
Jamil Hussain
