upgrade process for CUC 2.1.0.9901-362 to version suitable for CUCM 8.5.1
steven.wilson
I am upgrading a set of CUCM Pub and Sub to 8.5.1 the CUC is as above. What is the best method for upgrading as I can't seem to find it listed in Ciscounitytools COBRAS?
Rob Huffman
Hi Steven,
You are most correct CUC 2.x is not supported in COBRAS. Here is the guide you
need with the required steps;
Upgrading Cisco Unity Connection 2.x to the Shipping 8.0 or 8.5 Version
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/8x/upgrade/guide/8xcucrug010.html
Just keep this in mind, so you can plan accordingly
Supported Version Combinations for Cisco Unity Connection and Cisco Unified Communications Manager
Cisco Unity Connection 2.x and Later
Any version of Cisco Unity Connection 2.x or later is supported for use with any version of Cisco Unified CM 4.1(3) or later.
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/compatibility/matrix/cucsccpmtx.html
Cheers!
Rob
Rob Huffman
Hi Steven,
Cheers!
Rob
Thanks for the assistance, I'm having enough pain with the CUCMs. I don't really want a whole new world of hurt with the CUC.
Lots more documents to read then.
Cheers.
Rob Huffman
Hi Steven,
You are most welcome!
Lot's of planning/reading indeed. These upgrades are tough but with the proper due
diligence and bug srubs, can be very successful.
You have some time still for CUC 2.x
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6789/ps5745/ps6509/end_of_life_notice_c51-603504.html
Best of luck!
Rob
