Upgrade type from 10.5.2.10000-5 to 10.5.2.12900-14
FPENTEADO
Hi guys
Anybody knows if this upgrade from 10.5.2.10000-5 to 10.5.2.12900-14 is Linux 2 Linux or Refresh Upgrade?
Kind Regards
2 Accepted Solutions
john.welsh
Level 5
Level 5
This should be a standard (non-refresh) upgrade.
Jaime Valencia
RUs are only between major versions where you change the ESXi OS settings for the VM.
java
if this helps, please rate
john.welsh
Level 5
Level 5
Jaime Valencia
java
