ā02-14-2013 02:39 AM - edited ā03-16-2019 03:42 PM
Dear All
I want to upgrade unity from 4.0 to 9 , my question is :
- how the procedures it will be ?
- i will use cobra for inporting and exporting ??which version i will use ?
thanks and regards
ā02-14-2013 06:21 AM
You should start by reviewing the documentation
Upgrade Guide for Cisco Unity Connection Release 9.x
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/9x/upgrade/guide/9xcucrugx.html
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
ā02-14-2013 08:25 AM
You will definitley need to review the documentation that Java provided. In addition, you will need to ensure you are familiar with COBRAS and the 3 migration tools. High-level, you will definitely use COBRAS for this upgrade.
For Unity - you will install the COBRAS Export for Unity.
For Unity Connection - you will install the COBRAS Import for Unity Connection and the COBRAS Data Editor most likely on a workstation.
You can download the latest tools here:
http://www.ciscounitytools.com/Applications/General/COBRAS/COBRAS.html
And the Help Guide is here:
http://www.ciscounitytools.com/Applications/General/COBRAS/Help/COBRAS.htm
I also have a couple of older blogs on the topic so they may be of some use to you as well:
http://www.netcraftsmen.net/resources/technical-articles/825.html
http://www.netcraftsmen.net/user-group/c-mug-archive/824.html
Hailey
Please rate helfpul posts!
