02-24-2016 12:59 PM - edited 03-17-2019 06:00 AM
I cannot find the upgrade guide for Call Manager & Unity Connection 10.5.
Is this a pretty straight forward upgrade? Call Manager then Unity Publishers, then Call Manager the Unity Publishers?
02-24-2016 01:47 PM
It's the same procedure as it has always been since we moved to linux appliances, just make sure to read the RNs for that version in case any additional consideration has been added.
02-25-2016 10:39 PM
Hello Jaime,
Can you share any link which will give the details of bugs identified in version 10.5.X till now?
Ajith
02-25-2016 11:01 PM
Check Release Notes based on your version for the list of Open/Resolved caveats.
http://www.cisco.com/c/en/us/support/unified-communications/unified-communications-manager-callmanager/products-release-notes-list.html
Deepak
02-25-2016 11:04 PM
Ajith,
look for release notes for upgraded version.
regds,
aman
02-25-2016 07:47 PM
beyond what Jaime Valencia already said, you can use this link: Upgrade Guide for CUCM.
Hope this helps.
