Upgrading CUCM 7.0.2-20000-5 to 7.1.3
nikger1980
Hello pro's !
I have a CUCM cluster that runs on version 7.0.2-20000-5.
One publisher and one subscriber.
Last week, the publisher needed to be reinstalled, because of an inconsistency error.
After backing up the publisher, we have the following behavior.
All the ipphones register to the sub, normally, we make changes to the pub, it seems ok, but no changes are made to the phones.
For example, we cannot reset an ipphone from CUCM pub's web page.
When we restart the subscriber and the registration goes to publisher, the changes are possible.. !
Also, we can see some data replication alerts.
I believe that the bug "CSCso81531" is what we are facing right now.
"DB replication does not occur when connectivity is restored on lost node
Symptoms:
DB replication does not occur when connectivity is restored on lost node recovery"
So, i guess that an upgrade to a later version should solve the problem.
I believe that i will not have any licencing issues going to 7.1.3 and above version, right ?
All opinions are more than welcome..
Nick
Rob Huffman
Hi Nick,
First things first, there are no new Licenses required for a 7.0 to 7.1 upgrade
so you would be good to go there
I would try to repair the DB replication first using the Workaround shown in the Bug notes;
CSCso81531            Bug Details
Symptoms:
Condition:
Problem reproducible on Unison throttle4 v 7.0.0.39731-4
dbl_repl_output_Broadcast_... log has 0 length, and remains this way for more
than an hour.
(means the cdr check is stuck or very slow)
Failure seen in dbl_repl_cdr_Broadcast* log
Processing ccmdbtemplate_se013_pub3c_ccm7_0_0_39731_4_1_346_device with 30
rows group 6
------   Statistics for
ccmdbtemplate_se013_pub3c_ccm7_0_0_39731_4_1_346_device ------
Creating Shadow Repl sync_6530_131419_1208467904
(the cdr check is stuck in a loop here, due to a delete on device table)
Workaround:
"utils dbreplication stop" on the sub(s) - can run all at once
"utils dbreplication stop" on the pub (wait until the stop on the sub(s) is
complete)
"utils dbreplication clusterreset" from the pub When you run the command the
log name is listed, the file will be here:
file list activelog cm/trace/dbl/sdi*
file view activelog cm/trace/dbl/filename
watch file for status
"utils dbreplication reset all" from the pub
Stop and restart all the services on all the subs (or restart/reboot all the
systems (subs))  in the cluster to get the services changes.  Do this only
after "utils dbreplication status" shows status 2.
There is a direct upgrade path from 7.0(2) to 7.1(3) so that is good as well;
Table 7     Supported Cisco Unified Communications Manager Upgrades for Release 7.1(3x)
7.1(3b)SU2
7.1(3b)SU1
7.1(3b)
7.1(3a)SU1a
7.1(3a)SU1
7.1(3a)
7.1(3)
System Version
7.1.3.32900-4
7.1.3.31900-1
7.1.3.30000-1
7.1.3.21901-1
7.1.3.21900-4
7.1.3.20000-2
7.1.3.10000-11
Release Date
Feb 18 2010
Dec 15 2009
Dec 15 2009
Dec 8 2009
Dec 1 2009
Nov 4 2009
Sep 22 2009
Standard Support
Direct upgrade:
7.1(3b)SU1, 7.1(3b), 7.1(3a)SU1a, 7.1(3a)SU1, 7.1(3a), 7.1(3), 7.1(2b)SU1, 7.1(2b), 7.1(2a) SU1, 7.1(2a), 7.1(2), 7.0(2a)SU3, 7.0(2a)SU2, 7.0(2a)SU1, 7.0(2a), 7.0(2), 6.1(4a)SU2, 6.1(4a), 6.1(4)SU1, 6.1(4), 6.1(3b)SU1, 6.1(3b), 6.1(3a), 6.1(3)
Direct upgrade:
Direct upgrade:
7.1(3a), 7.1(3), 7.1(2b)SU1, 7.1(2b), 7.1(2a) SU1, 7.1(2a), 7.1(2), 7.0(2a)SU3, 7.0(2a)SU2, 7.0(2a)SU1, 7.0(2a), 7.0(2), 6.1(4a)SU2, 6.1(4a), 6.1(4)SU1, 6.1(4), 6.1(3b)SU1, 6.1(3b), 6.1(3a), 6.1(3), 5.1(3g), 5.1(3f), 5.1(3e)1, 5.1(3d), 5.1(3c), 5.1(3b), 5.1(3a), 5.1(3)
Direct upgrade:
Direct upgrade:
Direct upgrade:
7.1(3), 7.1(2b)SU1, 7.1(2b), 7.1(2a) SU1, 7.1(2a), 7.1(2), 7.0(2a)SU3, 7.0(2a)SU2, 7.0(2a)SU1, 7.0(2a), 7.0(2), 6.1(4a)SU2, 6.1(4a), 6.1(4)SU1, 6.1(4), 6.1(3b)SU1, 6.1(3b), 6.1(3a), 6.1(3), 5.1(3g), 5.1(3f), 5.1(3e)1 , 5.1(3d), 5.1(3c), 5.1(3b), 5.1(3a), 5.1(3)
Direct upgrade:
Direct upgrade using DMA:
none
none
4.3(2), 4.2(3), 4.1(3)
none
none
Note Refer to the Notes about Engineering Specials (ESs), Service Updates (SUs), and Windows Service Release (SR) Upgrades concerning upgrades from ESs.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/compat/ccmcompmatr.html#wp43011
After getting to 7.1(3), it has been recommended by many people here that 7.1(3b)SU2 is a very
stable build, so try to move in that direction right away.
Cheers!
Rob
Thanks Rob for your answer !
As i see to the Compatibility Matrix that you've posted, i could make a direct upgrade to the 7.1(3b)SU2, or i miss something?
Thanks again,
Nick
Rob Huffman
Hi Nick,
Yes, you are most correct my friend
I just checked using
Unified Communications Manager (CallManager) Upgrade Tool
and here is the outcome;
Introduction
This tool is used to identify the steps necessary to upgrade your Cisco Unified Communications Manager appliance.
Usage Guidelines
Pick the version you are uprading from and the version you are upgrading to.
Current Version
7.0.2.10000-18
Destination Version
7.1.3.32900-4
Release Information
  • CUCM 7.1(3b)SU2 was originally released on February 18, 2010.
  • The full version number is 7.1.3.32900-4.
  • The base ES for this version is 7.1.3.32012-1.
Download Information
  • The files required for this upgrade are available for download on cisco.com.
  • Click here to be directed to the Software Center downloads for CUCM.
Maintaining your inactive partition
  • You can upgrade to this version directly from your current version and maintain your current version in the inactive partition.
Licensing Information
  • There are no licensing changes or requirements involved with this upgrade.
Cheers!
Rob
