Upgrading CUCM/Unity Connection when running on insufficient Licenses
LibinBenedict
We are planning to upgrade our Unity Connection from 10.5 to 11.5 next month.
But, we have a situation wherein the contract tied to the licenses on the Unity Connection is expiring in a few days from now. So we have decided to upgrade the license before the actual upgrade of the application and put them in PLM 11.5. This will make the unity connection run with insufficient licenses since the application is in 10.5 and licenses in 11.5.
Can we upgrade Unity Connection (or for that matter CUCM) without clearing the license warning?
Libin Benedict
Hi Libin,
so yes, so will have a grace period that will let you to upgrade to your final release
REGARDS
Carlo
Please rate all helpful posts "The more you help the more you learn"
5 Replies 5
yes,during the license grace period, you'll still be able to upgrade UCNx
Carlo
Hi Carlo,
Is this applicable for all - CUCM and UCCX too?
Libin Benedict
Hi Libin,
Which version of UCCX are you coming from?
Even on uccx you could have a Grace period where upgrade to the final desired release.
Carlo
Hi Carlo,
Thank you for the information. we are on UCCX 10.6(1)SU2.
Libin Benedict
Hi Libin,
REGARDS
Carlo
