02-14-2010 02:40 PM - edited 03-15-2019 09:24 PM
We're configuring a UC500 with a sip trunk from Belgian provider 3starsnet. Outbound calls are working fine, however inbound is not working.
The inbound call is supposed to go to the AA on the cue module. but for simplicity I have configured 1 of the nbound numbers as a second extension on a phoneso we can test.
You can find the configuration and the debug ccsip all for an inbound call attached.
UC_520#show sip-ua register status
Line peer expires(sec) registered P-Associated-URI
089449040 -1 29 yes
Thanks for the urgent help.
Rgds,
Jeroen
02-14-2010 04:24 PM
Jeroen,
Can you try removing the "permission term" from dial-peer 1000. This is the dial-peer you are matching and the "permission term" statement is not going to allow you to accept incoming calls. See below for additional information:
After a dial peer is associated with an incoming call, the permission is checked to determine whether incoming calls are permitted on the dial peer. If permission is not set to orig or both, the incoming call is blocked.
After a dial peer is matched for an outgoing call, the permission is checked to determine whether outgoing calls are permitted on the dial peer. If permission is not set to term or both, the outgoing call using this dial peer fails.
Hope this helps,
Emilio
02-15-2010 12:53 PM
Hi Emilio,
Thanks for your reply. I have removed the permission term command (and have also tested both and orig) and still the call is failing.
What else can I try?
jeroen
02-15-2010 01:01 PM
I have removed the access list 2 together with the permission on the dial peer and this has resolved it.
I will check with theprovider which IP addresses they are sending from so I can add all of them back to the access list.
Thanks for your help,
Jeroen
10-07-2011 03:40 AM
Hi Jeroen,
Do you received the IP addresses from 3starsnet ?
Could you please post your working config ? Would be great !!
Kind Regards,
Christophe
