URI Dialling
cameronallison1
Hi Guys,
I'm having some problems and hope you can help.
When I dial 19710@domin.com it works but when I dial first.last@domain.com it doesn't work
I've checked the SIP profile to allow dial string interpretation with no luck
I've also ticked the "Use FQDN in SIP requests" with no luck
Any help would be appreciated
Cameron
2 Accepted Solutions
Yes, you need to enable URI dialing, and the DirectoryURI field is to adjust the mapping, that one is up to you, and your deployment.
java
if this helps, please rate
Cam,
the only line that I added to get URI dialing to work from Jabber is:
<EnableSIPURIDialling>True</EnableSIPURIDialling>
If you are saying when you put in first.last@domain.com into Jabber and the "green phone icon" does not appear, that your issue is most likely with Jabber.
Can you double check your jabber config file by going to:
http://<tftp Cucm IP address goes here>:6970/jabber-config.xml
and verify that SIP Uri dialing is indeed in there.
Please remember to rate useful posts, by clicking on the stars below.
7 Replies 7
Jaime Valencia
I'm assuming this is CUCM, as you don't mention what you use
And have you configured first.last@domain.com in your CUCM???
If you go to your route plan report, can you find it???
What troubleshooting have you done???
java
Hi Jaime,
Thanks for the fast response
CUCM 10.5
I have configured the uri under the DN
Its not present in the route plan report
as to troubleshooting I have tried many things -
Changing the SIP pattern
changing the SIP profile
When I enter first.last@domain.com into Jabber it doesn't even give me the option to dial
It SHOULD show up in the route plan report if it was properly configured
And not sure what the last thing you mentioned has anything to do, if you think that jabber somehow goes to CUCM and since it cannot find that URI, you don't get the option to call, no, it doesn't, you should get the option to dial anything you want. If you're not getting the option to call, that's a whole other problem.
Pretty much as a phone when you dial on-hook, you can dial whatever you want, once you send the digits, you find out whether your call hit something, or not.
java
Update, the phone now works with a speed dial but jabber will not allow my to enter
The green dial button doesn't illuminate when a uri is entered
Do I need to update the jabberlocalconfig.xml with -
<EnableSIPUriDialling>true</EnableSIPUriDialling>
<DirectoryURI>mail</DirectoryURI>
java
Cam,
Hi Jamie,
Issue was found in the jabber-config.xml file.
Just need to add the "EnableSIPUriDialling" and it worked
Thanks for your help
Cameron
