ā02-01-2011 09:18 AM - edited ā03-16-2019 03:12 AM
I have a question regarding pots lines into the system in a pbx mode.When I assign a line to a button on a user's phone to give the user the correct outbound caller Id. Will the incomming calls on that private line go to that users mailbox on a ring no answer ?
ā02-01-2011 01:14 PM
That depends on the configuration, you can configure if you want a call forward behavior or just let it ring.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
ā02-02-2011 05:05 AM
When you say configuration the phone is already configured to go to vmail on a RNA or busy. But the lines after you set them up there's not much you can do on a fxo port through the GUI interface. They are already assigned to the user as a direct C.O. should this work.
