Using AXL to update partition of Hunt PIlot?
carlnewton
Level 3
Level 3
Ive used a Perl script before to insert translation patterns from a CSV file into a call manager database, however, i now have a requirement to modify the partition that 350 hunt pilots sit in on a call manager 7.1.5.
Does anyone have an applicable script or can help me with any programming guides for this and/or the tags i need to use?
This would be much appreciated to save it having to be done manually!
Cheers
Craig Dyer
Level 3
Level 3
Hi Carl,
     Good to hear from you again.
     The best resource for Admin AXL is http://developer.cisco.com/web/axl
     The request you require will look like:-
     http://schemas.xmlsoap.org/soap/envelope/" xmlns:ns="http://www.cisco.com/AXL/API/8.0">
         $PTN
         $PART
         $NEWPART
     And as it's you have mailed you an copy of a script which will meet your needs.
All the best,
Craig
PLEASE RATE HELPFUL POSTS!
