02-17-2010 12:20 AM - edited 03-15-2019 09:26 PM
I have configured my 3845 voice gateway (using IOS c3845-ipvoicek9-mz.124-23.bin) with the correct cptone locale. My device is located in the Philippines so I used "cptone PH". However, I am not hearing the correct tone.
Any idea where the problem is?
Thank you.
Solved! Go to Solution.
02-17-2010 02:50 AM
Also it happens that in the same country different tones are used, or are sometime changed.
Please remember to rate useful posts clicking the stars below.
02-17-2010 01:47 AM
cptone can be wrong.
Use instead a custom cptone.
02-17-2010 02:13 AM
thank you... i tried using "cptone C1" and "cptone C2" and now i'm hearing the ringtone... but my question is, why "cptone PH" is not producing the correct tone? is this an IOS bug?
02-17-2010 02:50 AM
02-17-2010 03:02 AM
thank you
