Using VWIC-1MFT-T1 for voice PRI on a 2610XM
Hi, can not set this controller as a pri-group or ds0-group for CCS or CAS signaling.
In controller, only channel-group is available
CME_ROUTER(config-controller)#?
Controller configuration commands:
  cablelength    Specify the cable length for a DS1 link
channel-group  Specify the timeslots to channel-group mapping for an
                 interface
  clock          Specify the clock source for a DS1 link
  crc-threshold  Specify how many CRC errors per second to be treated as
                 severely errored second (SES)
  default        Set a command to its defaults
  description    Controller specific description
  detect         Enable detection of loopback request
  exit           Exit from controller configuration mode
  fdl            Specify the FDL standard for a DS1 data link
  framing        Specify the type of Framing on a DS1 link
  guard-timer    Guard timer (0-20) for xcsp calls - timer duration and
                 accept/reject on expiry
  help           Description of the interactive help system
  linecode       Specify the line encoding method for a DS1 link
  loopback       Put the entire T1 line into loopback
  mode           Configure the controller mode
  no             Negate a command or set its defaults
  shutdown       Shut down a DS1 link (send Blue Alarm)
  snmp           Modify SNMP controller parameters
Once Controller t1 is setup, It creates serial 0/1:1 as if it assigns it for data, but I need voice (ds0-group or pri-group)
any idea why IOS does not offer these setup ?
THANK YOU !
I have a 2610XM
CME_ROUTER#sh version
Cisco IOS Software, C2600 Software (C2600-IPVOICEK9-M), Version 12.4(15)T14, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Tue 17-Aug-10 05:40 by prod_rel_team
ROM: System Bootstrap, Version 12.2(8r) [cmong 8r], RELEASE SOFTWARE (fc1)
CME_ROUTER uptime is 48 minutes
System returned to ROM by reload at 06:14:54 UTC Sun Mar 3 2002
System image file is "flash:c2600-ipvoicek9-mz.124-15.T14.bin"
Cisco 2610XM (MPC860P) processor (revision 1.0) with 229376K/32768K bytes of memory.
Processor board ID JAD07090S87
M860 processor: part number 5, mask 2
1 FastEthernet interface
2 Serial interfaces
1 Channelized T1/PRI port
2 Voice FXO interfaces
2 Voice FXS interfaces
32K bytes of NVRAM.
49152K bytes of processor board System flash (Read/Write)
15 Replies 15
since it is only one 1 call in a LAB one PVDM-12 would be OK.
I will shop for the new hardware, thanks to all again !
