Using VWIC-1MFT-T1 for voice PRI on a 2610XM
Hi, can not set this controller as a pri-group or ds0-group for CCS or CAS signaling.
In controller, only channel-group is available
CME_ROUTER(config-controller)#?
Controller configuration commands:
  cablelength    Specify the cable length for a DS1 link
channel-group  Specify the timeslots to channel-group mapping for an
                 interface
  clock          Specify the clock source for a DS1 link
  crc-threshold  Specify how many CRC errors per second to be treated as
                 severely errored second (SES)
  default        Set a command to its defaults
  description    Controller specific description
  detect         Enable detection of loopback request
  exit           Exit from controller configuration mode
  fdl            Specify the FDL standard for a DS1 data link
  framing        Specify the type of Framing on a DS1 link
  guard-timer    Guard timer (0-20) for xcsp calls - timer duration and
                 accept/reject on expiry
  help           Description of the interactive help system
  linecode       Specify the line encoding method for a DS1 link
  loopback       Put the entire T1 line into loopback
  mode           Configure the controller mode
  no             Negate a command or set its defaults
  shutdown       Shut down a DS1 link (send Blue Alarm)
  snmp           Modify SNMP controller parameters
Once Controller t1 is setup, It creates serial 0/1:1 as if it assigns it for data, but I need voice (ds0-group or pri-group)
any idea why IOS does not offer these setup ?
THANK YOU !
I have a 2610XM
CME_ROUTER#sh version
Cisco IOS Software, C2600 Software (C2600-IPVOICEK9-M), Version 12.4(15)T14, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Tue 17-Aug-10 05:40 by prod_rel_team
ROM: System Bootstrap, Version 12.2(8r) [cmong 8r], RELEASE SOFTWARE (fc1)
CME_ROUTER uptime is 48 minutes
System returned to ROM by reload at 06:14:54 UTC Sun Mar 3 2002
System image file is "flash:c2600-ipvoicek9-mz.124-15.T14.bin"
Cisco 2610XM (MPC860P) processor (revision 1.0) with 229376K/32768K bytes of memory.
Processor board ID JAD07090S87
M860 processor: part number 5, mask 2
1 FastEthernet interface
2 Serial interfaces
1 Channelized T1/PRI port
2 Voice FXO interfaces
2 Voice FXS interfaces
32K bytes of NVRAM.
49152K bytes of processor board System flash (Read/Write)
of course you need the NM and the DSP modules. Look at your offer, you maybe see if the DSP banks are occupied.
PVDM-12 are suitable for NM-HDV. Maximum configuration are fifth.
If not, you need at least one depending on how many channels you will occupy and which voice codec is used.
  • "Each PVDM-12 contains 3 TI 549 DSPs.
    • Runs up to twelve voice calls using a medium complexity CODEC             (G.711, G.729a/b, G.726, fax).
    • Runs up to six voice calls using a high complexity CODEC (G.729,             G.728, G.723.1).
    • PVDM-12 fits into SIMM sockets on the NM-1HDV network module
    • Five PVDM SIMM sockets on the NM-1HDV network module"
    Source: http://www.cisco.com/en/US/tech/tk652/tk701/technologies_tech_note09186a00800b65d6.shtml
    knott2011
    15 Replies 15
    Found this: - still dont tell us how to config...
    Cisco 2600/2600XM/2691/3700 Chassis WIC Slot
    When the Multi-Flex Trunk is used in the chassis WIC slot, each T1 can be configured with a channel group to generate a virtual serial interface in the running configuration. At most, you can have two channel groups per VWIC. This means that a 1-port VWIC T1 controller can be configured with (at most) two channel-groups, and a 2-port VWIC can be configured with (at most) two channel-groups on one T1 controller or one channel-group per T1 controller.
    If the Cisco 2600/2600XM also has an AIM-VOICE-30 or AIM-ATM-VOICE-30 card installed, one T1 controller can be configured as an ISDN PRI or Channel Associated Signaling (CAS) Telephony voice interface. You can configure more than one T1 controller as an ISDN PRI or CAS Telephony voice interface for the Cisco 2691/3700 which can have more than one AIM VOICE card installed.
    Anas Abueideh
    Level 9
    Level 9
    check if you have enough dsp. or try to upgrade the IOS if possible.
    Anas
    please rate if it is helpful
    Sent from Cisco Technical Support Android App
    The version is the latestin found for 2600XM router c2600-ipvoicek9-mz.124-15.T14
    for the DSP, the only ones I know about are the ones for my FXO FXS on my MN-2V...
    I tried to upgrade to c2600-ipvoicek9-mz.124-25d, - latest ios-  same problem, still no access to pri-group or ds0-group
    looks like I need to assign it as a serial interface...
    Anyone can assist with this configuration ?
    Hi Jean,
    Can u share the show inventory/show diag  of Cisco router ?
    regds,
    aman
    There it is:
    CME_ROUTER#sh diag
    Slot 0:
            C2610XM 1FE Mainboard Port adapter, 3 ports
            Port adapter is analyzed
            Port adapter insertion time unknown
            EEPROM contents at hardware discovery:
            Hardware Revision        : 1.0
            PCB Serial Number
            Part Number              : 73-7677-02
            RMA History              : 00
            RMA Number               : 0-0-0-0
            Board Revision           : B0
            Deviation Number         : 0-0
            Product (FRU) Number     : C2610XM-1FE
            EEPROM format version 4
            EEPROM contents (hex):
              0x00: 04 FF 40 03 6A 41 01 00 C1 0B FF FF FF 46 46 46
              0x10: 46 FF FF FF FF 82 49 1D FD 02 04 00 81 00 00 00
              0x20: 00 42 42 30 80 00 00 00 00 FF FF FF FF FF FF FF
              0x30: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
              0x40: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
              0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
              0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
              0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
            WIC Slot 0:
            Serial 1T WAN daughter card
            Hardware revision 1.1           Board revision F0
            Serial number     11263084      Part number    73-1775-02
            FRU Part Number     WIC-1T=
            Test history      0x0           RMA number     00-00-00
            Connector type    Wan Module
            EEPROM format version 1
              0x20: 01 02 01 01 00 AB DC 6C 49 06 EF 02 00 00 00 00
              0x30: 78 00 00 00 98 11 09 01 FF FF FF FF FF FF FF FF
            WIC Slot 1:
            T1 (1 port) Multi-Flex Trunk WAN daughter card
            Hardware revision 1.0           Board revision F0
            Serial number     32547787      Part number    800-03568-03
            FRU Part Number     VWIC-1MFT-T1=
            Connector type    PCI
              0x20: 01 20 01 00 01 F0 A3 CB 50 0D F0 03 00 00 00 00
              0x30: 78 00 00 00 04 08 01 00 FF FF FF FF FF FF FF FF
    Slot 1:
            4 PORT Voice PM for C2600 Port adapter
            Hardware revision 1.1           Board revision H0
            Serial number     24260142      Part number    800-02491-02
            FRU Part Number     NM-2V=
              0x00: 01 65 01 01 01 72 2E 2E 50 09 BB 02 00 00 00 00
              0x10: 88 00 00 00 01 01 11 17 FF FF FF FF FF FF FF FF
              0x20: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
            VIC Slot 0:
            FXO Voice daughter card (2 port)
               Unknown EEPROM ver 16
            EEPROM format version 16
              0x20: 10 0D 01 01 01 A0 C3 70 50 09 BF 01 00 00 00 00
              0x30: A0 00 00 00 02 01 09 01 FF FF FF FF FF FF FF FF
            VIC Slot 1:
            FXS Voice daughter card (2 port)
            Hardware revision 1.1           Board revision B0
            Serial number     22691812      Part number    800-02493-04
              0x20: 01 0E 01 01 01 5A 3F E4 50 09 BD 04 00 00 00 00
              0x30: 58 00 00 00 01 12 27 01 FF FF FF FF FF FF FF FF
    CME_ROUTER#sh invent
    NAME: "2610XM chassis", DESCR: "2610XM chassis"
    PID: C2610XM-1FE       , VID: 1.0, SN: JAD07090S87
    NAME: "WAN Interface Card - Serial (1T) on Slot 0 Subslot 0", DESCR: "WAN Interface Card - Serial (1T)"
    PID: WIC-1T=           , VID: 1.1, SN: 11263084
    NAME: "One port T1 voice interface daughtercard on Slot 0 Subslot 1", DESCR: "One port T1 voice interface daughtercard"
    PID: VWIC-1MFT-T1=     , VID: 1.0, SN: 32547787
    NAME: "C2600 4 port Voice PM on Slot 1", DESCR: "C2600 4 port Voice PM"
    PID: NM-2V=            , VID: 1.1, SN: 24260142
    NAME: "Two port FXO voice interface daughtercard on Slot 1 Subslot 0", DESCR: "Two port FXO voice interface daughtercard"
    PID: VIC-2FXO=         , VID: 1.1, SN: 27313008
    NAME: "Two port FXS voice interface daughtercard on Slot 1 Subslot 1", DESCR: "Two port FXS voice interface daughtercard"
    PID: VIC-2FXS=         , VID: 1.1, SN: 22691812
    You do not have the DSP module indicated in your post above.
    Anyway, the 2600 are obsolete, get at least an ISR G1. You will be able to re-use the VWIC card.
    This is for a CCNA VOICE LAB, I dont have another ISR. I have a 2811 but no T1 card for it.
    DSP should not prevent me from configuring the pri-group or ds0-group ? I might be missing some DSP hardware, but Cisco documentation confirms this card is supported with this router, just need to get the configuration. from some one who knows.
    Hi Jean,
    The NM-2V card cannot be used with VWIC-1MFT-T1 card .Supporting Cisco URL
    http://www.cisco.com/en/US/docs/routers/access/interfaces/nm/hardware/installation/guide/OvrNetM.html
    As said by Mr. Paolo, PVDMs are not appearing in show inventory, you need to have PVDM2 can be used only in conjuction with HDV2 NMs.
    Please find supporting Link.
    http://www.cisco.com/en/US/prod/collateral/routers/ps259/product_data_sheet0900aecd800fa5be.pdf
    regds,
    aman
    Thanks for the links and info.
    The NM-2V card is for my FSX and FSO. (1/1) - they work OK
    VWIC-1MFT-T1 is connected to a diffetent stand alone slot. (1/0)
    Do you mean I need to add a DSP card inside the router ? because there is no room on the router for another  NM-2v type of card and the VWIC-1MFT-T1 has it's own slot.
    I got this VWIC-1MFT-T1 on ebay for 5$, no one talked about adding DSP !!!
    Hi Jean,
    For Pri-group command to appear , u need to have DSPs/PVDMs on router. Cisco 2600XM router does not have on-board DSP slot that is the reason , we need to go for Voice NM which can have PVDMs inserted on them.
    regds,
    aman
    Patrick Knott
    Since you are using the Cisco 2600 you have only the possibility of an AIM-VOICE-30.
    http://www.cisco.com/en/US/products/hw/modules/ps2641/products_data_sheet09186a0080088753.html
    The other method is to insert the VWIC into a NM (NM-HDV) with enough DSPs.
    Goes not because the slot is indeed busy.
    Without AIM and NM you can only use the card for data applications.
    knott2011
    Thanks to all for the help.
    I found a Cisco NM-HDV Genuine for $20 on ebay.
    Does the NM-HDV comes with enough DSP to operate a LAB ? or do I need to buy one PVDM module on top of this ?
    Of course I will need to remove the MN-2V / FXO FXS  for the T1 and PRI labs...
    What do you think ?
    knott2011
