utilizing existing sip circuit terminated on cisco voice gateway over the wan for alcatel pbx
rajuchandu87
Dear all,
I have one requirement from my client they want to utilize the existing sip circuit which contains 1000 DID/DOD numbers 58XXX terminated on cisco voice gateway 3945 and being used by cisco for 500 users and require to use 200 numbers over the wan for the remote alcatel pbx site.Is this possible.
the Call Flow: SIP Provider---CUBE---H323---CUCM8.5
Ex: if they use  200 numbers 588XX to 58999 if any calls come for this numbers it should go to the alcatel pbx. can anybody provide me the best approach to deal with this type of situation with some sample configuration.
Thanks and Regards.
Ayodeji Okanlawon
What is the integration between the alcatel pbx and the gateway? Is it TDM or is it SIP?
ALl you need to do is configure dial-peers with destination-pattern 588XX and send it to the alcatel PBX..Its that simple
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
