06-19-2013 06:48 AM - edited 03-16-2019 05:58 PM
Dear All,
I am using one cisco Router 2800 as a E1 PRI connected with the service provider. E1 is working fine i tired it everything is good. The main problem i am facing is that E1 router also contain FXS ports and that FXS ports i connected to Cisco UC-500 on UC analog trunks (FXO). The problem i am facing is when any user from UC-500 try to dial PSTN number the calls hit to e1 router without any destination number. due to that call is not going to PSTN. I am not able to understand how i figure out this.
06-19-2013 06:56 AM
You have a wrong configuration but without seeing all the details it's impossible to say more.
06-20-2013 01:01 AM
Thanks for the reply. Onething i want to ask, the design i define is workable? And if possible please sent me any sample comfiguration.
06-20-2013 06:17 AM
Yes it s doable. I recommend you engage a reputable consultant or UC certfied ciso partner, instead of trying to do yourself.
