10-19-2011 06:56 AM - edited 03-16-2019 07:35 AM
hy
Is there any command i can use to verify that i am using H.323 protocol in my voice gateway if so kindly reply
Thanks in advance
P.Vishvak
10-19-2011 07:02 AM
Try
show h323 gateway
show h323 call -- Shows live H323 calls
clear h323 gateway -- This ZEROs the stats
Alex
10-19-2011 07:14 AM
You can use show gateway. That command will show you if H.323 service is up. H.323 is default in Cisco voice gateways.
You can use show show mgcp, show ccm-manager hosts and show ccm-manager backhaul to verify if you're using CallManager to control the voice gateway endpoints with MGCP.
Hope it helps, please rate if it does.
- Adrian.
