10-30-2008 12:27 PM - edited 03-15-2019 02:16 PM
How can I verify hotfixes and patches that have been applied to Windows 2000 server
10-30-2008 12:30 PM
I usually go to start---->settings----->control panel----->add/remove programs....scroll through this list and you should see which hotfixes have been applied to your server.
Hope that helped, if so please rate.
10-30-2008 12:31 PM
very simple, go to add/remove programs and you will see them
java
if this helps, please rate
