Verifying T1 Line Down.
bijoyjackjesse
Hey Guys.
There are 2 T1 lines configured, and one of them went down. I ran the "sh isdn status" cmd in VG, one of them shows for Layer 2 "TEI_Assigned and the other one is up which shows as "Multiple Frame Established".. and one of the Controllers is down.. But light glows for both the T1 ports in the MCS Server. I just wanted to make sure, if the fault is with Telco or if there is anything else i need to check before calling up the Telco..
Thanks for your help..
paolo bevilacqua
Unless a cable has been pulled, it's telco failure.
