New Extensions range
hussainirfan
HI All
If i want to add New extension range on call Manager so should i only creat partition and CSS for that OR i have to add that extension range anywhere else.
Example :
We have existing extension range from 501 --> 599 and now i want to add new extension range from 3001 --->3999. Sould i add new extension anywhere or  just add new extension i.e 3001 and add the new partition and CSS on that.
Please advice.
5 Replies 5
V.Naveen Kumar
Do mean that you are going change extension number of the IP phone.
use your BAT for bulk changes
No i want to add new extension numbers range with existing extensions in call menager for users.
tell me exactly what you are going to do..??
you need add new extension range for new ip phone..??
r
you need replace existing extension into new extension..???
Yes i need to add new extension range for new ip phones.
No one can tell you that, that's up to you and your dial plan design.
Whether you need a new PT/CSS for those new DNs, is YOUR choice.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
