vg 224 limitation in CME
I have to connect a vg 224 to a CME router ,
Is there is a limitation of how may vg224 can be conected to the CME ?
Does the limit of the ip phones and dn numbers are alos related to the analog ports like the VG ?
Or I need to look for something else ?
Yaniv
paolo bevilacqua
If you configure the ports is SCCP mode, will be limited by maxium ephones supported by teh CME router.
Otherwise, no limitation whatsoever.
