VG-310
John Huthmaker
Level 4
Level 4
I've been asked to do some research in to installing a Cisco VG 310.  I wanted to see if anyone on the support forums have installed one before.  I did some poking around, and configured a mock one in my home lab.  It looks like its really just a basic voice gateway (router) with a ton of FXS ports.  It looks like its best to just set it up as an MGCP gateway, and then configure your ports as you would any other FXS port in CUCM.  Is that correct, or am I missing something?
2 Accepted Solutions
Wilson Samuel
Level 7
Level 7
Hi John
As far as I know, the Supplementary Services are much better served with the SCCP in VG3XX or VG2XX GWs.
So, in essence, it will be best if you can configured the GW in SCCP mode
http://www.cisco.com/c/en/us/products/collateral/unified-communications/vg-series-gateways/product_data_sheet09186a00801d87f6.html
Terry Cheema
Yes its got lot of fxs ports but it does support TDM and other protocols as well apart from MGCP, Refer:
Protocols Supported
The voice gateways support the following protocols:
   SCCP
   H.323v4
   MGCP
   SIP
   Real-Time Transport Protocol (RTP)
   Secure Real-Time Transport Protocol (SRTP)
   Trivial File Transfer Protocol (TFTP)
   HTTP server
   SNMP
   Telnet
   Dynamic Host Configuration Protocol (DHCP)
   Domain Name System (DNS)
   Cisco Unified Communications Manager or Cisco Unified Communications Manager Express redundancy support using Hot Standby Router Protocol (HSRP)
   Call survivability: MGCP failover to an H.323 connection to the SRST router
   Cisco Fax Relay, T.38 fax relay, and modem pass-through
   Coder/decoder (codec) support, G.711, and G.729a
   RADIUS and TACACS+ for Telnet and authorization
Also refer to technical specifications.
Also Refer here: http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/admin/10_0_1/ccmsys/CUCM_BK_SE5FCFB6_00_cucm-system-guide-100/CUCM_BK_SE5FCFB6_00_cucm-system-guide-100_chapter_0100110.html#CUCM_RF_V83D221A_00
Cisco VG310
MGCP
T1/CAS/PRI
E1/PRI
FXS/FXO/BRI
SCCP
FXS/BRI
H.323 and SIP
T1/CAS/PRI
E1/PRI
FXS/FXO/BRI
Refer to this post as well someone asked this couple of days ago:
https://supportforums.cisco.com/discussion/12561676/using-vg310-voice-router-wpri
-Terry
Please rate all helpful posts
8 Replies 8
Wilson Samuel
Level 7
Level 7
Hi John
Wilson looks like we are replying to the questions at same time :)
-Terry
Ha ha, that was a nice co-incidence :-)
regards
Thanks for the help guys.  This is all good info.
Just wanted to follow up.  I installed the VG310 at a client site yesterday.  It was pretty seamless.  I did a "sho int g0/0" to get the mac address, and added it to CUCM with a SCCP integration. Once adding a couple commands at the interface, and adding the interface to CUCM it came right up.  It was much easier than I anticipated, and worked well.  I was able to get a 10 page fax in without any issue, and the client uses SIP trunks.
Glad that we were able to help
Good one John - thanks for the update! (+5)
-Terry
Terry Cheema
Protocols Supported
   SCCP
   H.323v4
   MGCP
   SIP
   HTTP server
   SNMP
   Telnet
Cisco VG310
MGCP
T1/CAS/PRI
E1/PRI
FXS/FXO/BRI
SCCP
FXS/BRI
H.323 and SIP
T1/CAS/PRI
E1/PRI
FXS/FXO/BRI
-Terry
