VG202 Configured as H323 gateway does not support variable digits
Ayodeji Okanlawon
Guys,
I have been working on these for a few days and here is a description of my proble..
I have VG202 configured as h323 gateway ( we had to use h323 due to some sccp issues)..
I have dial-peers set up as
dial-peer voice 20 voip
preference 1
destination-pattern .T
voice-class codec 1
voice-class h323 1
session target ipv4:10.x.x.x
dtmf-relay h245-alphanumeric
ip qos dscp cs3 signaling
no vad
When I plug in an analogue phone to one of the fxs ports and dial any number, The gateway does digit collection..but the call is never matched to any dial-peer.
When I do the same call again with # at the end of the number to indicate end of digit dialling, the call works
When I configure a specific pattern eg (07...........), the call works without the need for sending #
I have done loads of troubleshooting and it just comes down to the fact that with the "T" in my dial-peer the VG202 is unable to know when the digit dialling is done and then create a setup request
The IOS in the gateway is this..fvg20x-ipvoice-mz.124-22.T5.bin
I even ried to upgrade the IOS to vg20x-advipservicesk9-mz.151-4.M6.bin and to  my horror this code crashed one of the VGs...
Any one seen this...
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
bernhardczapp
Level 4
Level 4
"destination-pattern .T" should match.
did you try to set a shorter interdigit timeout on the voice-port?
I have got a similar config here working:
voice-port 0/0
cptone DE
timeouts interdigit 3
voice-port 0/1
cptone DE
timeouts interdigit 2
dial-peer voice 100 voip
session target ipv4:x.x.x.x
codec g711alaw
dial-peer voice 1 pots
incoming called-number .
port 0/1
bernhardczapp
Level 4
Level 4
voice-port 0/0
cptone DE
voice-port 0/1
cptone DE
codec g711alaw
port 0/1
Bernhard! If I had a million dollars I will send it your way right now!
I set the timer on the voice port to 10s, but that dint work 3s did the magic! You dont know what a big help you have done. Really Appreciate it! Awesome man..Just great...You can tell I am excited because of the hours this has taken..
