ā03-30-2015 12:59 AM - edited ā03-17-2019 02:29 AM
Existing CUCM ( 8.6 ), VoiceGateway is MGCP--- - E1 voice gateway with out voice gateway version c3900-universalk9-mz.SPA. 151-4 per cent. M6. bin,VG202 version vg20x-ipvoice-mz. 150-1 per cent.M9. Bin ; the questions : the Send is erro ,the Receive is ok . How to configure?
hostname CNTJ-VG202-01
boot-start-marker
boot-end-marker
enable secret 5 $1$..xP$SFc0s2YJGToSBVuEkzn9v1
no aaa new-model
clock timezone GST 8
ip source-route
ip cef
no ip domain lookup
no ipv6 cef
stcapp ccm-group 1
stcapp
stcapp supplementary-services
port 0/0
fallback-dn 40224666
voice service voip
fax protocol pass-through g711ulaw
modem passthrough nse codec g711ulaw
voice-card 0
username cisco secret 5 $1$3gZT$Meh3fgX08D970LVcie/hN0
interface FastEthernet0/0
ip address 10.165.6.7 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
ip default-gateway 10.165.6.1
ip forward-protocol nd
no ip http server
ip route 0.0.0.0 0.0.0.0 10.165.6.1
control-plane
voice-port 0/0
ring cadence pattern06
mwi
cptone CN
timeouts ringing infinity
caller-id enable
voice-port 0/1
mwi
cptone CN
caller-id enable
sccp local FastEthernet0/0
sccp ccm 10.165.24.2 identifier 1 version 7.0
sccp
sccp ccm group 1
bind interface FastEthernet0/0
associate ccm 1 priority 1
switchback method graceful
dial-peer voice 500 pots
service stcapp
port 0/0
dial-peer voice 501 pots
service stcapp
port 0/1
line con 0
no modem enable
line aux 0
line vty 0 4
password cisco
login local
ā03-30-2015 05:32 PM
There needs to be consistancy with the fax protocol config throughout the network
So on the vg202 you have
voice service voip
Thats fine - so we are going to use fax/modem passthru as the protocol.
In the ccm page you shared set the options to match
Modem Passthrough = Enable
T38 Faxelay = Disable
Save & reset
On the MGCP gateway
ccm-manager fax protocol cisco
mgcp fax t38 inhibit
mgcp modem passthrough voip mode nse
mgcp modem passthrough voip codec g711ulaw
Alex
ā03-30-2015 08:01 PM
Hi Alex,
Thank you for your help!
I have configured VG202:
voice service voip
h323
Cisco Fax Relay = Enable ?
Save & reset
On the MGCP gateway
Tips: Reset the Gateway on CCM if this Gateway registered with Cisco Call Manger (CCM)
I also need Reset the voice gateway on CCM if this gateway registered with CCM?
