VG20XXM - SIP Option is not working
silvervoip
Hello Community,
I recently installed 8 VG20XXM analog gateway to my CUCM cluster via SIP TRUNK but seeing this error;
Not In full service (please check SS).
In the SIP on CUCM, it says; status down, status reason local=1
I have another model gateways with same configuration but they work properly. What might be the problem?
Jaime Valencia
That code is request timeout, make sure there is nothing preventing the connectivity and that all the IP/hostname/fqdn in use are the correct ones and resolvable.
java
if this helps, please rate
Hello, Yes it is resolvable, connection is stable.
Please add a "show run" from the VG and also enable the following -
debug ccsip mesasge
debug ccsip non-call
Let it run for sometime and then collect them and attach here.
