VG224 cannot fax/call to external
jfrackiewicz
we are experiencing an identical problem with fax in two different locations. We plugged an analog telephone into the VG224 Patchpanel, we can call the phone from external (sometimes it rings sometimes not, but you can answer the call). But the problem is, we cannot call outside to PSTN or internal to a VOIP Phone, I cannot see anything on the Voice Gateway. The problem exists in two different locations, which are separated but they run over the same CUCM Subscriber in again a different location. Both concerned locations got their own Voice Gateway.
VG224 Config from Location 1:
! No configuration change since last restart
! NVRAM config last updated at 09:00:28 GMT Wed Feb 18 2015
version 15.1
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
hostname xxxxx
boot-start-marker
boot-end-marker
logging buffered 64000
logging rate-limit 1 except errors
logging console errors
enable secret 5 xxxx
aaa new-model
aaa local authentication attempts max-fail 10
aaa authentication login default group tacacs+ local
aaa authentication login AUTHLIST-EXEC local-case
aaa authentication login console local
aaa authentication enable default group tacacs+ enable
aaa authorization exec default group tacacs+ local
aaa accounting commands 15 default start-stop group tacacs+
aaa session-id common
clock timezone GMT 1 0
clock summer-time GMT recurring last Sun Mar 2:00 last Sun Oct 3:00
ip source-route
ip cef
no ip domain lookup
ip domain name xxxxxx
login on-failure log
login on-success log
no ipv6 cef
stcapp ccm-group 1
stcapp
stcapp supplementary-services
 port 2/0
  fallback-dn 49945120216
 port 2/1
  fallback-dn 49945120219
 port 2/2
  fallback-dn 49945120220
 port 2/3
  fallback-dn 49945120224
 port 2/4
  fallback-dn 49945120225
 port 2/5
  fallback-dn 49945120229
 port 2/6
  fallback-dn 49945120230
 port 2/7
  fallback-dn 49945120235
 port 2/8
  fallback-dn 49945120240
 port 2/9
  fallback-dn 49945120241
 port 2/10
  fallback-dn 49945120245
 port 2/11
  fallback-dn 49945120255
 port 2/12
  fallback-dn 49945120213
 port 2/13
  fallback-dn 49945120265
 port 2/14
  fallback-dn 49945120270
 port 2/15
  fallback-dn 49945120285
 port 2/16
  fallback-dn 49945120289
 port 2/17
  fallback-dn 49945120290
 port 2/18
  fallback-dn 49945120291
 port 2/19
  fallback-dn 49945120297
 port 2/20
  fallback-dn 49945120300
 port 2/21
  fallback-dn 49945120330
 port 2/22
  fallback-dn 49945120340
 port 2/23
  fallback-dn 49945120488
voice service pots
 fax rate disable
voice service voip
 fax protocol pass-through g711ulaw
 modem passthrough nse codec g711ulaw
voice-card 0
username VGWAdmin secret 5 xxxxxxx
interface FastEthernet0/0
 description Voice VLAN
 ip address xxxxxx 255.255.252.0
 duplex auto
 speed auto
interface FastEthernet0/1
 no ip address
 shutdown
 duplex auto
 speed auto
ip default-gateway xxxxxx
ip forward-protocol nd
no ip http server
ip route 0.0.0.0 0.0.0.0 xxxxxx
logging xxxx
logging xxxx
logging xxxx
access-list 10 permit xxx
access-list 10 remark SNMP-Server-ACL
access-list 10 permit xxxx
access-list 10 permit xxxxx
tacacs-server host xxxxx
tacacs-server directed-request
tacacs-server key 7 xxxx
snmp-server community xxx
snmp-server community xxxx
snmp-server enable traps config
snmp-server host xxxx
control-plane
voice-port 2/0
 cptone DE
 timeouts ringing infinity
voice-port 2/1
 cptone DE
voice-port 2/2
 cptone DE
voice-port 2/3
 cptone DE
voice-port 2/4
 cptone DE
voice-port 2/5
 cptone DE
voice-port 2/6
 cptone DE
voice-port 2/7
 cptone DE
voice-port 2/8
 cptone DE
voice-port 2/9
 cptone DE
voice-port 2/10
 cptone DE
voice-port 2/11
 cptone DE
voice-port 2/12
 cptone DE
voice-port 2/13
 cptone DE
voice-port 2/14
 cptone DE
voice-port 2/15
 cptone DE
voice-port 2/16
 cptone DE
voice-port 2/17
 cptone DE
voice-port 2/18
 cptone DE
voice-port 2/19
 cptone DE
voice-port 2/20
 cptone DE
voice-port 2/21
 cptone DE
voice-port 2/22
 cptone DE
voice-port 2/23
 cptone DE
mgcp profile default
sccp local FastEthernet0/0
sccp ccm 172.20.172.20 identifier 10 priority 1 version 7.0
sccp ccm 172.17.44.6 identifier 20 priority 2 version 7.0
sccp
sccp ccm group 1
 bind interface FastEthernet0/0
 associate ccm 10 priority 1
 associate ccm 20 priority 2
 switchback method graceful
dial-peer voice 500 pots
 service stcapp
 port 2/0
dial-peer voice 501 pots
 service stcapp
 port 2/1
dial-peer voice 502 pots
 service stcapp
 port 2/2
dial-peer voice 503 pots
 service stcapp
 port 2/3
dial-peer voice 504 pots
 service stcapp
 port 2/4
dial-peer voice 505 pots
 service stcapp
 port 2/5
dial-peer voice 506 pots
 service stcapp
 port 2/6
dial-peer voice 507 pots
 service stcapp
 port 2/7
dial-peer voice 508 pots
 service stcapp
 port 2/8
dial-peer voice 509 pots
 service stcapp
 port 2/9
dial-peer voice 510 pots
 service stcapp
 port 2/10
dial-peer voice 511 pots
 service stcapp
 port 2/11
dial-peer voice 512 pots
 service stcapp
 port 2/12
dial-peer voice 513 pots
 service stcapp
 port 2/13
dial-peer voice 514 pots
 service stcapp
 port 2/14
dial-peer voice 515 pots
 service stcapp
 port 2/15
dial-peer voice 516 pots
 service stcapp
 port 2/16
dial-peer voice 517 pots
 service stcapp
 port 2/17
dial-peer voice 518 pots
 service stcapp
 port 2/18
dial-peer voice 519 pots
 service stcapp
 port 2/19
dial-peer voice 520 pots
 service stcapp
 port 2/20
dial-peer voice 521 pots
 service stcapp
 port 2/21
dial-peer voice 522 pots
 service stcapp
 port 2/22
dial-peer voice 523 pots
 service stcapp
 port 2/23
line con 0
line aux 0
 no exec
line vty 0 4
 session-timeout 5
 length 0
 transport input all
ntp server xxxx
ntp server xx
end
Voice Gateway Location 1
boot-start-marker
boot-end-marker
card type e1 0 0
card type e1 0 1
no logging queue-limit
logging buffered 51200 warnings
aaa new-model
aaa authentication login default local
aaa authentication login AUTHLIST-EXEC group tacacs+ local-case
aaa authentication login AUTHLIST-LOCAL local-case
aaa authentication login AUTHORLIST-EXEC local
aaa authorization console
aaa authorization exec AUTHORLIST-EXEC group tacacs+ local
aaa authorization network default local
memory-size iomem 15
network-clock-participate wic 0
network-clock-participate wic 1
network-clock-select 1 E1 0/0/0
network-clock-select 2 E1 0/0/1
network-clock-select 3 E1 0/1/0
no ipv6 cef
no ip domain lookup
ip domain name yourdomain.com
ip cef
isdn switch-type primary-net5
voice-card 0
 dspfarm
 dsp services dspfarm
voice call send-alert
voice call disc-pi-off
voice call convert-discpi-to-prog
voice rtp send-recv
voice service voip
 ip address trusted list
  ipv4 xxx
  ipv4 xxx
  ipv4 xxxx
 h323
  h225 timeout t302 2
  h225 signal overlap
  h225 start-h245 on-connect
  call preserve limit-media-detection
voice class codec 10
 codec preference 6 g711alaw
 codec preference 8 g711ulaw
 codec preference 10 g729br8
 codec preference 11 g729r8
 codec preference 12 ilbc
voice class h323 10
  call start fast
voice translation-rule 10
 rule 1 /^00/ /\1/ type any international plan any isdn
 rule 2 /^0/ /\1/ type any national plan any isdn
 rule 3 /^[1-9]/ /\0/ type any subscriber plan any isdn
voice translation-rule 11
 rule 1 /^\(.*\)/ /00\1/ type national national
 rule 2 /^\(.*\)/ /000\1/ type international international
 rule 3 /^\(.*\)/ /0\1/ type subscriber subscriber
voice translation-rule 100
 rule 1 /^200/ /49945120699/
 rule 2 /^20/ /49945120\1/
voice translation-rule 500
 rule 1 /^0\(01028.*\)/ /0\1/
 rule 2 /^0\([1-9].*\)/ /00102809451\1/
 rule 3 /^00\(.*\)/ /0010280\1/
 rule 4 /^000\(.*\)/ /00102800\1/
voice translation-rule 1000
 rule 1 /^49945120/ /945120\1/ type unknown national
voice translation-profile PSTN-IN
 translate calling 11
 translate called 100
voice translation-profile PSTN-OUT-PRESELECTION
 translate called 500
voice translation-profile SRST-OUT
 translate calling 1000
license udi pid C3900-SPE100/K9 sn xx
hw-module pvdm 0/0
archive
 log config
  logging enable
  logging size 400
  notify syslog contenttype plaintext
  hidekeys
 path flash:ARCHIVE-CONFIG_
 write-memory
 time-period 1440
memory reserve critical 1000
file verify auto
username dns password 7 1510020200
username voipadmin password 7 03120B5A365B36494C
redundancy
controller E1 0/0/0
 pri-group timeslots 1-31
controller E1 0/0/1
controller E1 0/1/0
controller E1 0/1/1
class-map match-any VOICE-RTP
 match  dscp ef
class-map match-any VOICE-SIGNAL
 match  dscp af31
 match  dscp cs3
policy-map VOICE
 class VOICE-RTP
  priority percent 10
 class VOICE-SIGNAL
  bandwidth percent 1
 class class-default
  fair-queue
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/0
 ip address 172.17.56.9 255.255.252.0
 duplex auto
 speed auto
 h323-gateway voip bind srcaddr xxxx
 service-policy output VOICE
interface GigabitEthernet0/1
 no ip address
 shutdown
 duplex auto
 speed auto
interface GigabitEthernet0/2
 no ip address
 shutdown
 duplex auto
 speed auto
interface Serial0/0/0:15
 no ip address
 encapsulation hdlc
 isdn overlap-receiving T302 2000
 isdn incoming-voice voice
 isdn send-alerting
 isdn sending-complete
 no cdp enable
interface Serial0/0/1:15
 no ip address
 encapsulation hdlc
 shutdown
 isdn send-alerting
 no cdp enable
interface Serial0/1/0:15
 no ip address
 encapsulation hdlc
 shutdown
 isdn send-alerting
 no cdp enable
ip default-gateway 172.17.56.1
no ip http server
no ip http secure-server
control-plane
voice-port 0/0/0:15
 translation-profile incoming PSTN-IN
 translation-profile outgoing SRST-OUT
 echo-cancel coverage 32
 echo-cancel mode 1
 cptone DE
 bearer-cap 3100Hz
voice-port 0/1/0:15
 echo-cancel mode 1
 cptone DE
 bearer-cap 3100Hz
voice-port 0/0/1:15
 echo-cancel mode 1
 cptone DE
 bearer-cap 3100Hz
sccp local GigabitEthernet0/0
sccp ccm xx identifier 3 version 7.0
sccp ccm xx identifier 2 version 7.0
sccp ccm xx identifier 1 version 7.0
sccp
sccp ccm group 1
 bind interface GigabitEthernet0/0
 associate ccm 1 priority 1
 associate ccm 2 priority 2
 associate ccm 3 priority 3
 associate profile 1 register CFBSSCHVGW01
dspfarm profile 1 conference
 codec g722-64
 codec g711ulaw
 codec g711alaw
 codec g729ar8
 codec g729abr8
 codec g729br8
 maximum sessions 16
 associate application SCCP
dial-peer voice 100 voip
 destination-pattern 49945120T
 session target ipv4:xx
 voice-class codec 10
 voice-class h323 10
 dtmf-relay h245-signal h245-alphanumeric rtp-nte
 ip qos dscp cs3 signaling
 no vad
dial-peer voice 110 voip
 voice-class h323 10
 no vad
dial-peer voice 120 voip
 voice-class h323 10
 no vad
dial-peer voice 10 pots
 tone ringback alert-no-PI
 preference 1
 destination-pattern 0T
 progress_ind setup enable 3
 progress_ind progress enable 8
 direct-inward-dial
 port 0/0/0:15
dial-peer voice 997 voip
 preference 10
 incoming called-number .
 no vad
dial-peer voice 998 voip
 preference 4
 session target ipv4:xxx
 no vad
dial-peer voice 999 voip
 preference 2
 no vad
gateway
 timer receive-rtp 1200
gatekeeper
 shutdown
call-manager-fallback
 secondary-dialtone 0
 max-conferences 8 gain -6
 transfer-system full-consult
 ip source-address xx port 2000
 max-ephones 450
 max-dn 500
 system message primary SRST Operation Mode
 dialplan-pattern 1 49945120... extension-length 3
line con 0
 login authentication AUTHLIST-EXEC
line aux 0
 no exec
line 2
 no activation-character
 no exec
 transport preferred none
 transport input all
 transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line vty 0 4
 session-timeout 5
 exec-timeout 30 0
 privilege level 15
 transport input telnet ssh
 transport output ssh
line vty 5 6
 session-timeout 5
 privilege level 15
line vty 7 15
 privilege level 15
 no exec
scheduler allocate 20000 1000
ntp update-calendar
ntp server xxx
ntp server xxx
end
Please give some advise.
Chris Deren
Since you are using SCCP for the control of the analog ports you need to check on CUCM side to ensure the ports have proper CSS/Device Pool assigned to make calls.  Compare the CSS on the device/line to an IP phone at the same location.
Wilson Samuel
Level 7
Level 7
Just adding to the point of Chris, the easiest way to do would be do a DNA from those ports.
jfrackiewicz
Thanks for the answers, but CSS etc. are ok. Also the output from the DNA. This worked till last Wednesday. I made some traces on the VG and I can see that the first one or two calls are delivered to the end device. After that I can only see a ringing for about one second and then nothing is happening.I attached the trace file.
