VG224 fax incoming/outgoing issues
Mohd Marzuki
When i dialled to the extension connected to fax machine, it's kept ringing without going to the fax tone.
So users can't receive incoming fax and send outgoing fax.
Plug in the analog phone to that fax line, i can heard the tone normally.
It's connected to VG224.
Any advice?
Can we see some configs please
Best Regards
Can we see some configs please on the vg224
Best Regards
Hi Hermanus, FYI no answer ring duration (second) had been set to 30s.
version 12.4
no service pad
service password-encryption
hostname PTT351-T1-L45-VG224-01
boot-start-marker
boot-end-marker
logging message-counter syslog
aaa new-model
aaa session-id common
clock timezone MY 8
ip source-route
ip cef
ip domain name
no ipv6 cef
stcapp ccm-group 1
stcapp
stcapp feature access-code
stcapp feature speed-dial
voice service pots
fax rate disable
voice service voip
fax protocol pass-through g711ulaw
h323
  no h225 timeout keepalive
modem passthrough nse codec g711ulaw
voice-card 0
username voiceadmin password 7 107E0C0D17471C0A1F557878
archive
log config
  hidekeys
ip ssh time-out 10
ip ssh authentication-retries 2
ip ssh version 2
interface FastEthernet0/0
description ***VG224.TOWER1.LEVEL45***
ip address 10.6.71.240 255.255.255.0
duplex full
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 10.6.71.254
no ip http server
no ip http secure-server
snmp-server engineID local 1234567890
snmp-server group Snmp@dm!n v3 priv match exact
snmp-server group E2E_MONGRP v3 priv match exact
snmp-server view E2E_VIEW mib-2 included
snmp-server view E2E_VIEW cisco included
snmp-server community monitorcuom RO
snmp-server enable traps snmp linkdown linkup coldstart warmstart
snmp-server enable traps config
snmp-server enable traps envmon
snmp-server enable traps flash insertion removal
snmp-server enable traps cpu threshold
snmp-server enable traps dsp card-status
snmp-server enable traps dsp oper-state
snmp-server enable traps voice
snmp-server host 10.14.17.156 version 3 priv Snmp@dm!n
snmp-server host 10.14.17.157 version 3 priv Snmp@dm!n
control-plane
voice-port 2/0
timeouts initial 60
timeouts interdigit 60
timeouts ringing infinity
voice-port 2/1
timeouts initial 60
voice-port 2/2
timeouts initial 60
voice-port 2/3
timeouts initial 60
voice-port 2/4
timeouts initial 60
voice-port 2/5
timeouts initial 60
voice-port 2/6
timeouts initial 60
voice-port 2/7
timeouts initial 60
voice-port 2/8
timeouts initial 60
voice-port 2/9
timeouts initial 60
voice-port 2/10
timeouts initial 60
voice-port 2/11
timeouts initial 60
voice-port 2/12
timeouts initial 60
voice-port 2/13
timeouts initial 60
voice-port 2/14
timeouts initial 60
voice-port 2/15
timeouts initial 60
voice-port 2/16
timeouts initial 60
voice-port 2/17
timeouts initial 60
voice-port 2/18
timeouts initial 60
voice-port 2/19
timeouts initial 60
voice-port 2/20
timeouts initial 60
voice-port 2/21
timeouts initial 60
voice-port 2/22
timeouts initial 60
voice-port 2/23
timeouts initial 60
ccm-manager fax protocol cisco
ccm-manager config server 10.14.17.35 10.7.194.36
ccm-manager sccp local FastEthernet0/0
ccm-manager sccp
mgcp fax t38 ecm
mgcp behavior g729-variants static-pt
sccp ccm 10.14.17.35 identifier 1 priority 1 version 7.0
sccp ccm 10.14.17.36 identifier 2 priority 2 version 7.0
sccp ccm 10.7.194.36 identifier 3 priority 3 version 7.0
sccp ccm 10.7.194.37 identifier 4 priority 4 version 7.0
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate ccm 3 priority 3
associate ccm 4 priority 4
switchback method graceful
dial-peer voice 999200 pots
service stcapp
port 2/0
dial-peer voice 999201 pots
service stcapp
port 2/1
dial-peer voice 999202 pots
service stcapp
port 2/2
dial-peer voice 999203 pots
service stcapp
port 2/3
dial-peer voice 999204 pots
service stcapp
port 2/4
dial-peer voice 999205 pots
service stcapp
port 2/5
ntp server 170.38.254.141
ntp server 170.38.254.142
end
Please add the following 2 line to your pots dial-peers and test again:
service stcapp
port 2/0
incoming called-number .
direct-inward-dial
Best Regards
