06-26-2013 05:14 AM - edited 03-16-2019 06:05 PM
Hi guys.
I get fast busy tone on the vg224 ports when it works in srst mode here is a sample of my config:
application
global
service alternate Default
interface FastEthernet0/0
ip address 192.168.91.210 255.255.255.0
duplex auto
speed auto
ip default-gateway 192.168.91.251
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.91.251
voice-port 2/0
cptone RU
timeouts initial 15
timeouts interdigit 5
timeouts call-disconnect 0
timeouts ringing infinity
caller-id enable
sccp local FastEthernet0/0
sccp ccm 192.168.91.251 identifier 3 priority 3 version 4.1
sccp ccm 192.168.91.8 identifier 1 priority 1 version 4.1
sccp ccm 192.168.91.7 identifier 2 priority 2 version 4.1
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate ccm 2 priority 2
associate ccm 3 priority 3
switchback method graceful
dial-peer voice 20 pots
service stcapp
fax rate disable
port 2/0
dial-peer voice 120 pots
description USED IN SRST
preference 1
destination-pattern 101
port 2/0
dial-peer voice 88888 voip
destination-pattern 9T
session target ipv4:192.168.91.251
VG224(config)#do show sccp
SCCP Admin State: UP
Gateway IP Address: 192.168.91.210, Port Number: 2000
IP Precedence: 5
User Masked Codec list: None
Call Manager: 192.168.91.251, Port Number: 2000
Priority: 3, Version: 4.1, Identifier: 3
Call Manager: 192.168.91.8, Port Number: 2000
Priority: 1, Version: 4.1, Identifier: 1
Call Manager: 192.168.91.7, Port Number: 2000
Priority: 2, Version: 4.1, Identifier: 2
Alg_Phone Oper State: ACTIVE - Cause Code: NONE
Active Call Manager: 192.168.91.251, Port Number: 2000
TCP Link Status: CONNECTED, Device Name: AN940F4FF5B8400
Reported Max Streams: 1, Reported Max OOS Streams: 0
Supported Codec: g711ulaw, Maximum Packetization Period: 20
Supported Codec: g711alaw, Maximum Packetization Period: 20
Supported Codec: g729ar8, Maximum Packetization Period: 220
Supported Codec: g729br8, Maximum Packetization Period: 220
Supported Codec: g729r8, Maximum Packetization Period: 220
Supported Codec: NSE VBD, Maximum Packetization Period: 20
TCP Link Status: CONNECTED, Device Name: AN940F4FF5B8401
TCP Link Status: CONNECTED, Device Name: AN940F4FF5B8402
Can some one help please.
Solved! Go to Solution.
06-26-2013 10:23 AM
What do you see in your SRST when doing "show ephone" ?
If no DN you'll have to add a station-id number under each voice-ports on the VG224 to get the SRST to be populate with the Directo Numbers
06-26-2013 05:46 AM
What about "show stcapp dev summ"? Are the Ports showing registered? Do they show the extension?
Can you post the complete configuration?
You can capture:
debug voip application stcapp port [voice-port number]
debug vpm signal
debug sccp event
debug voip ccapi inout
Jorge Armijo
Please remember to rate helpful responses and identify helpful or correct answers.
06-26-2013 06:25 AM
Thanks Jorge Armijo for your reply .
Here are the outputs:
1-ports are not registered !!
VG224#show stcapp device summary
Total Devices: 24
Total Calls in Progress: 0
Total Call Legs in Use: 0
Port Device Device Call Dev Directory Dev
Identifier Name State State Type Number Cntl
2/0 AN940F4FF5B8400 INIT UNREGISTERED ALG 101 UNKN
2/1 AN940F4FF5B8401 INIT UNREGISTERED ALG 102 UNKN
2/2 AN940F4FF5B8402 INIT UNREGISTERED ALG 103 UNKN
2/3 AN940F4FF5B8403 INIT UNREGISTERED ALG 104 UNKN
2/4 AN940F4FF5B8404 INIT UNREGISTERED ALG 105 UNKN
2/5 AN940F4FF5B8405 INIT UNREGISTERED ALG 109 UNKN
2/6 AN940F4FF5B8406 INIT UNREGISTERED ALG 110 UNKN
2/7 AN940F4FF5B8407 INIT UNREGISTERED ALG 111 UNKN
2/8 AN940F4FF5B8408 INIT UNREGISTERED ALG 112 UNKN
2/9 AN940F4FF5B8409 INIT UNREGISTERED ALG 113 UNKN
2/10 AN940F4FF5B840A INIT UNREGISTERED ALG 114 UNKN
2/11 AN940F4FF5B840B INIT UNREGISTERED ALG 115 UNKN
2/12 AN940F4FF5B840C INIT UNREGISTERED ALG 118 UNKN
2/13 AN940F4FF5B840D INIT UNREGISTERED ALG 119 UNKN
2/14 AN940F4FF5B840E INIT UNREGISTERED ALG 120 UNKN
2/15 AN940F4FF5B840F INIT UNREGISTERED ALG 121 UNKN
2/16 AN940F4FF5B8410 INIT UNREGISTERED ALG 122 UNKN
2/17 AN940F4FF5B8411 INIT UNREGISTERED ALG 123 UNKN
2/18 AN940F4FF5B8412 INIT UNREGISTERED ALG 128 UNKN
2/19 AN940F4FF5B8413 INIT UNREGISTERED ALG 132 UNKN
2/20 AN940F4FF5B8414 INIT UNREGISTERED ALG 133 UNKN
2/21 AN940F4FF5B8415 INIT UNREGISTERED ALG 134 UNKN
2/22 AN940F4FF5B8416 INIT UNREGISTERED ALG 135 UNKN
2/23 AN940F4FF5B8417 INIT UNREGISTERED ALG 136 UNKN
2-) it's matching the wrong dial-peer 27 when it should match dial-peer 127
dial-peer voice 127 pots
preference 1
destination-pattern 111
port 2/7
dial-peer voice 27 pots
service stcapp
fax rate disable
port 2/7
VG224#debug voip application stcapp port 2/7
VG224#
*Mar 1 02:41:59.939: //-1/BD252B788041/CCAPI/cc_api_display_ie_subfields:
cc_api_call_setup_ind_common:
cisco-username=
----- ccCallInfo IE subfields -----
cisco-ani=
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=0
cisco-rdnsi=0
cisco-redirectreason=0
*Mar 1 02:41:59.939: //-1/BD252B788041/CCAPI/cc_api_call_setup_ind_common:
Interface=0x63005630, Call Info(
Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=(TON=Unknown, NPI=Unknown),
Calling Translated=FALSE, Subsriber Type Str=RegularLine, FinalDestinationFlag=FALSE,
Incoming Dial-peer=27, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=FALSE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-
VG224#1
*Mar 1 02:41:59.939: //-1/BD252B788041/CCAPI/ccCheckClipClir:
In: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Out: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
*Mar 1 02:41:59.939: //22/BD252B788041/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Call Info(Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=(TON=Unknown, NPI=Unknown))
*Mar 1 02:41:59.943: //22/BD252B788041/CCAPI/cc_process_call_setup_ind:
Event=0x62FBCF68
>>>>CCAPI handed cid 22 with tag 27 to app "stcapp"
*Mar 1 02:41:59.943: ==> Received event:STCAPP_CC_EV_CALL_SETUP_IND (evId:CC_EV_CALL_SETUP_IND) for CallId: 22
*Mar 1 02:41:59.943: 2/7 : Call State:UNREGISTERED
*Mar 1 02:41:59.943: 2/7 : stcapp_unreg_setup_ind_eh
*Mar 1 02:41:59.943: //22/BD252B788041/CCAPI/ccCallDisconnect:
Cause Value=41, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Cause Value=41, Call Entry(Responsed=TRUE, Cause Value=41)
*Mar 1 02:41:59.943: //22/BD252B788041/CCAPI/cc_api_get_transfer_info:
Transfer Number Is Null
*Mar 1 02:41:59.943: 2/7 : No state change
VG224#
VG224#
*Mar 1 02:42:04.767: //22/BD252B788041/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x63005630, Tag=0x0, Call Id=22,
Call Entry(Disconnect Cause=41, Voice Class Cause Code=0, Retry Count=0)
Call Disconnect Event Sent
VG224#debug vpm signal
Voice Port Module signaling debugging is enabled
VG224#
*Mar 1 02:47:16.895: [2/7] c2400_report_sig_state: ABCD = 0xC
*Mar 1 02:47:16.895: port 7 changed state new state = 12
*Mar 1 02:47:16.899: htsp_process_event: [2/7, FXSLS_ONHOOK, E_DSP_SIG_1100]fxsls_onhook_offhook htsp_setup_ind
*Mar 1 02:47:16.899: [2/7] get_local_station_id calling num= calling name= calling time=03/01 02:47 orig called=
*Mar 1 02:47:16.899: //-1/7A12095F8044/CCAPI/cc_api_display_ie_subfields:
cisco-username=
cisco-ani=
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=0
cisco-rdnsi=0
*Mar 1 02:47:16.899: //-1/7A12095F8044/CCAPI/cc_api_call_setup_ind_common:
VG224#tation=Allowed),
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
*Mar 1 02:47:16.903: //-1/7A12095F8044/CCAPI/ccCheckClipClir:
*Mar 1 02:47:16.903: //23/7A12095F8044/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
*Mar 1 02:47:16.903: //23/7A12095F8044/CCAPI/cc_process_call_setup_ind:
Event=0x62FBCF68
>>>>CCAPI handed cid 23 with tag 27 to app "stcapp"
*Mar 1 02:47:16.903: ==> Received event:STCAPP_CC_EV_CALL_SETUP_IND (evId:CC_EV_CALL_SETUP_IND) for CallId: 23
*Mar 1 02:47:16.903: 2/7 : Call State:UNREGISTERED
*Mar 1 02:47:16.903: 2/7 : stcapp_unreg_setup_ind_eh
*Mar 1 02:47:16.903: //23/7A12095F8044/CCAPI/ccCallDisconnect:
*Mar 1 02:47:16.903: //23/7A12095F8044/CCAPI/cc_api_get_transfer_info:
*Mar 1 02:47:16.903: 2/7 : No state change
*Mar 1 02:47:16.903: htsp_pre_connect_disconnect, cdb = 623FC288 cause = 29
*Mar 1 02:47:16.907: htsp_process_event: [2/7, FXSLS_WAIT_SETUP_ACK, E_HTSP_PRE_CONN_DISC]
VG224#
VG224#
*Mar 1 02:47:21.831: [2/7] c2400_report_sig_state: ABCD = 0x4
*Mar 1 02:47:21.831: port 7 changed state new state = 4
*Mar 1 02:47:21.835: htsp_process_event: [2/7, FXSLS_WAIT_SETUP_ACK, E_DSP_SIG_0100]fxsls_wait_setup_onhook
*Mar 1 02:47:21.835: htsp_timer - 1000 msec
VG224#
*Mar 1 02:47:22.835: htsp_process_event: [2/7, FXSLS_W_SETUP_ACK_ONHOOK, E_HTSP_EVENT_TIMER]fxsls_onhook_setup_ack_timer
*Mar 1 02:47:22.835: htsp_timer_stop
*Mar 1 02:47:22.835: htsp_process_event: [2/7, FXSLS_W_SETUP_ACK_ONHOOK, E_HTSP_RELEASE_REQ]fxsls_wait_setup_release
*Mar 1 02:47:22.835: //23/7A12095F8044/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x63005630, Tag=0x0, Call Id=23,
VG224#
06-26-2013 06:39 AM
The ports are not registered, so debugs at this point are not really helpfull.
sccp
On the aboove config, is any of those ip address the SRST GW?
Jorge Armijo
06-26-2013 06:45 AM
sccp ccm 192.168.91.251 identifier 3 priority 3 version 4.1 (this is the srst router).
Do i need to configure an ephone for the analog ports ?
06-26-2013 06:47 AM
You shouldn't...
Are you using call-manager-fallback?
What is the max-ephones configured for srst?
Can you see the registration attempt from the VG224 on the SRST GW?
Jorge Armijo
06-26-2013 06:50 AM
Depending on the current SRST version, you may change the following line:
**5,6 or 7+
Jorge Armijo
06-26-2013 07:06 AM
The one i configured 4.X is the latest on the vg224
06-26-2013 07:05 AM
on the 2901 srst router:
voice-card 0
dsp services dspfarm
voice service pots
voice service voip
ip address trusted list
ipv4 192.168.91.7 255.255.255.255
ipv4 192.168.91.8 255.255.255.255
ipv4 192.168.91.210 255.255.255.255
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
h323
h225 timeout setup 3
no h225 timeout keepalive
call preserve
interface GigabitEthernet0/1.1
encapsulation dot1Q 1 native
ip address 192.168.91.251 255.255.255.0
interface GigabitEthernet0/1.2
encapsulation dot1Q 2
ip address 192.168.92.251 255.255.255.0
application
global
ccm-manager fallback-mgcp
ccm-manager redundant-host 192.168.91.7
ccm-manager mgcp
mgcp
mgcp call-agent 192.168.91.8 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp bind control source-interface GigabitEthernet0/1.1
mgcp bind media source-interface GigabitEthernet0/1.1
mgcp profile default
sccp local GigabitEthernet0/1.1
sccp ccm 192.168.91.7 identifier 2 priority 2 version 7.0
sccp ccm 192.168.91.8 identifier 1 priority 1 version 7.0
sccp
sccp ccm group 1
associate profile 1 register TOMSK_HW_CONF
dspfarm profile 1 conference
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 3
associate application SCCP
dial-peer voice 10 pots
service mgcpapp
port 0/1/0
dial-peer voice 11 pots
service mgcpapp
port 0/1/1
dial-peer voice 12 pots
service mgcpapp
port 0/1/2
dial-peer voice 13 pots
service mgcpapp
port 0/1/3
other dial-peers for outgoing calls,i am just showing the internal dial-peers
dial-peer voice 28 voip
description To CUCM Primary
destination-pattern [1,2,3]..
session target ipv4:192.168.91.8
voice-class codec 1
dtmf-relay rtp-nte h245-signal h245-alphanumeric
dial-peer voice 31 voip
description To CUCM Secondary
preference 1
session target ipv4:192.168.91.7
voice-class codec 1
dial-peer voice 40 voip
preference 2
session target ipv4:192.168.91.210
voice-class codec 1
secondary-dialtone 9
max-conferences 8 gain -6
transfer-system full-consult
ip source-address 192.168.91.251 port 2000
max-ephones 42
max-dn 50 dual-line
IP phones fail over works but the vg224 don't
Thanks for your help and time.
06-26-2013 10:23 AM
06-27-2013 01:42 AM
Thank you so so much guy.richard.
Finally worked but on the srst router still doesnot show the dn when i issue show ephone but works ,do you know any document that is covering vg224 in srst mode,i searched but couldn't find.
Thanks again .
06-27-2013 02:12 AM
Glad this helped you.
I do not know good documentation on this subject. Only some experiences (good ones and bad ones)
Depending on what IOS version you use you may use also "fallback-dn xxxx" under
"stcapp supplementary-services" "voice-port".
Configuring SRST gateway as n+1 ccm in SCCP
I think you've made the job
06-27-2013 02:19 AM
Something else
voice-port x
station-id number 8482451
caller-id enable
If I remumber I effectively saw CG224 ephone-dn's in SRST
06-27-2013 02:22 AM
Sorry can you explain to me more what you meant about this new configuration,can u provide me a sample config.
I also now have other problem the analog phones can't call the ip phones but calls externally work normal while the ip phones can call internally and externally.
Can you help me in this also ,it's my first time to work with vg224.
Thanks in advance.
06-27-2013 02:28 AM
IS it could be cause these ip phones has the same dn shared with the analog phones.
normally not in srst mode these line are shared between analog phones and ip phones.
