02-08-2019 10:15 AM - edited 03-17-2019 02:05 PM
IOS vg224-i6s-mz.124-4.T8.bin
I have a line used for a deaf user connected to VG224. The line has dial tone and can make calls out but incoming calls do not ring the phone. I have tried reloading the VG and resetting that port.
Here is the debug voip ccapi inout and debug vpm sig
HQVG224#config t
Enter configuration commands, one per line. End with CNTL/Z.
HQVG224(config)#voice-port 2/19
HQVG224(config-voiceport)#shut
HQVG224(config-voiceport)#no shut
HQVG224(config-voiceport)#^Z
HQVG224#sh voice port summ
IN OUT
PORT CH SIG-TYPE ADMIN OPER STATUS STATUS EC
2/0 -- fxs-ls up dorm on-hook idle y
2/1 -- fxs-ls up dorm on-hook idle y
2/2 -- fxs-ls down down on-hook idle y
2/3 -- fxs-ls up dorm on-hook idle y
2/4 -- fxs-ls up dorm on-hook idle y
2/5 -- fxs-ls up dorm on-hook idle y
2/6 -- fxs-ls up dorm on-hook idle y
2/7 -- fxs-ls up dorm on-hook idle y
2/8 -- fxs-ls up dorm on-hook idle y
2/9 -- fxs-ls up dorm on-hook idle y
2/10 -- fxs-ls up dorm on-hook idle y
2/11 -- fxs-ls up dorm on-hook idle y
2/12 -- fxs-ls up dorm on-hook idle y
2/13 -- fxs-ls up dorm on-hook idle y
2/14 -- fxs-ls up dorm on-hook idle y
2/15 -- fxs-ls up dorm on-hook idle y
2/16 -- fxs-ls up dorm on-hook idle y
2/17 -- fxs-ls up dorm on-hook idle y
2/18 -- fxs-ls up dorm on-hook idle y
2/19 -- fxs-ls up dorm on-hook idle y
HQVG224#cl log
% Ambiguous command: "cl log"
HQVG224#clear log
Clear logging buffer [confirm]y
HQVG224#sh log
Syslog logging: enabled (1 messages dropped, 1 messages rate-limited,
0 flushes, 0 overruns, xml disabled, filtering disabled)
Console logging: disabled
Monitor logging: level debugging, 0 messages logged, xml disabled,
filtering disabled
Buffer logging: level debugging, 17467 messages logged, xml disabled,
filtering disabled
Logging Exception size (4096 bytes)
Count and timestamp logging messages: enabled
Trap logging: level informational, 105 message lines logged
Logging to 10.100.6.105(global) (udp port 514, audit disabled, link up), 105 message lines logged, xml disabled,
filtering disabled
Log Buffer (500000 bytes):
008393: Feb 8 2019 12:03:56.386 CST: //-1/xxxxxxxxxxxx/CCAPI/ccIFCallSetupReque stPrivate:
Interface=0x63146298, Interface Type=6, Destination=, Mode=0x9,
Call Params(Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
Subsriber Type Str=, FinalDestinationFlag=FALSE, Outgoing Dial-peer=0, Call C ount On=FALSE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Appl ication Call Id=A0000000027eb3f6000000F5)
008394: Feb 8 2019 12:03:56.390 CST: //186/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequ estPrivate:
SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
008395: Feb 8 2019 12:03:56.390 CST: //186/xxxxxxxxxxxx/CCAPI/ccCallSetContext:
Context=0x635533B8
008396: Feb 8 2019 12:03:56.390 CST: //-1/xxxxxxxxxxxx/CCAPI/ccIFCallSetupReque stPrivate:
Interface=0x62EFE2C8, Interface Type=9, Destination=0.0.0.0, Mode=0x9,
Subsriber Type Str=, FinalDestinationFlag=FALSE, Outgoing Dial-peer=0, Call C ount On=TRUE,
008397: Feb 8 2019 12:03:56.390 CST: //187/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequ estPrivate:
SPI Call Setup Request Is Success; Interface Type=9, FlowMode=1
008398: Feb 8 2019 12:03:56.390 CST: //187/xxxxxxxxxxxx/CCAPI/ccCallSetContext:
Context=0x63552EE8
008399: Feb 8 2019 12:03:56.390 CST: htsp_timer_stop3
008400: Feb 8 2019 12:03:56.394 CST: //187/xxxxxxxxxxxx/CCAPI/cc_api_call_conne cted:
Interface=0x62EFE2C8, Data Bitmask=0x0, Progress Indication=NULL(0),
Connection Handle=0
008401: Feb 8 2019 12:03:56.394 CST: //187/xxxxxxxxxxxx/CCAPI/cc_api_call_conne cted:
Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)htsp_setup_req
008402: Feb 8 2019 12:03:56.398 CST: htsp_process_event: [2/19, FXSLS_ONHOOK, E _HTSP_SETUP_REQ]fxsls_onhook_setup
008403: Feb 8 2019 12:03:56.398 CST: //186/xxxxxxxxxxxx/CCAPI/cc_api_call_proce eding:
Interface=0x63146298, Progress Indication=NULL(0)
008404: Feb 8 2019 12:03:56.398 CST: //186/xxxxxxxxxxxx/CCAPI/ccCallModify:
Nominator=0x1000, Params=0x6343FDB0, Call Id=186
008405: Feb 8 2019 12:03:56.398 CST: //186/xxxxxxxxxxxx/CCAPI/ccCallReportDigit s:
(callID=0xBA, digit_event=0x1, enable=TRUE, consume=FALSE)
008406: Feb 8 2019 12:03:56.398 CST: //186/xxxxxxxxxxxx/CCAPI/ccCallReportDigit s:
Enabled=TRUE, Call Id=186
008407: Feb 8 2019 12:03:56.402 CST: //186/xxxxxxxxxxxx/CCAPI/cc_api_call_repor t_digits_done:
(vdbPtr=0x63146298, callID=0xBA, disp=0, digit_event=0x1, enable=TRUE, consum e=FALSE)
008408: Feb 8 2019 12:03:56.402 CST: //186/xxxxxxxxxxxx/CCAPI/cc_api_call_repor t_digits_done:
Enabled=TRUE, Disposition=0x0, Interface=0x63146298, Call Id=186
008409: Feb 8 2019 12:03:56.402 CST: //186/xxxxxxxxxxxx/CCAPI/cc_api_call_repor t_digits_done:
Call Entry(Initial Digit Timeout=10000(ms), Inter Digit Timeout=10000(ms))
008410: Feb 8 2019 12:03:56.402 CST: //186/xxxxxxxxxxxx/CCAPI/ccConferenceCreat e:
(confID=0x6343FF54, callID1=0xBA, callID2=0xBB, tag=0x0)
008411: Feb 8 2019 12:03:56.402 CST: //186/xxxxxxxxxxxx/CCAPI/ccConferenceCreat e:
Conference Id=0x6343FF54, Call Id1=186, Call Id2=187, Tag=0x0
008412: Feb 8 2019 12:03:56.402 CST: htsp_call_bridged invoked
008413: Feb 8 2019 12:03:56.402 CST: //186/xxxxxxxxxxxx/CCAPI/cc_api_bridge_don e:
Conference Id=0x55, Source Interface=0x63146298, Source Call Id=186,
Destination Call Id=187, Disposition=0x0, Tag=0xFFFFFFFF
008414: Feb 8 2019 12:03:56.402 CST: //187/xxxxxxxxxxxx/CCAPI/cc_api_bridge_don e:
Conference Id=0x55, Source Interface=0x62EFE2C8, Source Call Id=187,
Destination Call Id=186, Disposition=0x0, Tag=0x0
008415: Feb 8 2019 12:03:56.402 CST: //186/xxxxxxxxxxxx/CCAPI/cc_generic_bridge _done:
008416: Feb 8 2019 12:03:56.402 CST: //186/xxxxxxxxxxxx/CCAPI/ccConferenceCreat e:
Call Entry(Conference Id=0x55, Destination Call Id=187)
008417: Feb 8 2019 12:03:56.402 CST: //187/xxxxxxxxxxxx/CCAPI/ccConferenceCreat e:
Call Entry(Conference Id=0x55, Destination Call Id=186)
008418: Feb 8 2019 12:03:56.402 CST: //186/xxxxxxxxxxxx/CCAPI/cc_api_caps_ind:
Destination Interface=0x62EFE2C8, Destination Call Id=187, Source Call Id=186 ,
Caps(Codec=0x1, Fax Rate=0x1, Vad=0x1,
Modem=0x2, Codec Bytes=20, Signal Type=3)
008419: Feb 8 2019 12:03:56.402 CST: //186/xxxxxxxxxxxx/CCAPI/cc_api_caps_ind:
Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
Playout Max=200(ms), Fax Nom=300(ms))
008420: Feb 8 2019 12:03:56.406 CST: //187/xxxxxxxxxxxx/CCAPI/cc_api_caps_ind:
Destination Interface=0x63146298, Destination Call Id=186, Source Call Id=187 ,
Caps(Codec=0x1, Fax Rate=0x2, Vad=0x1,
Modem=0x2, Codec Bytes=160, Signal Type=2)
008421: Feb 8 2019 12:03:56.406 CST: //187/xxxxxxxxxxxx/CCAPI/cc_api_caps_ind:
Playout Max=250(ms), Fax Nom=300(ms))
008422: Feb 8 2019 12:03:56.406 CST: //187/xxxxxxxxxxxx/CCAPI/cc_api_caps_ack:
Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=OFF(0x1),
Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=1895)
008423: Feb 8 2019 12:03:56.406 CST: //186/xxxxxxxxxxxx/CCAPI/cc_api_caps_ack:
008424: Feb 8 2019 12:03:56.406 CST: //186/xxxxxxxxxxxx/CCAPI/cc_process_notify _bridge_done:
Conference Id=0x55, Call Id1=186, Call Id2=187
008425: Feb 8 2019 12:03:56.410 CST: //186/xxxxxxxxxxxx/CCAPI/cc_api_call_modif y_done:
Result=0, Interface=0x63146298, Call Id=186
008426: Feb 8 2019 12:03:56.410 CST: htsp_process_event: [2/19, FXSLS_WAIT_OFFH OOK, E_HTSP_VOICE_CUT_THROUGH]fxsls_waitoff_voice
008427: Feb 8 2019 12:03:56.414 CST: //186/xxxxxxxxxxxx/CCAPI/cc_api_voice_mode _event:
Call Id=186
008428: Feb 8 2019 12:03:56.414 CST: //186/xxxxxxxxxxxx/CCAPI/cc_api_voice_mode _event:
Call Entry(Context=0x635533B8)
008429: Feb 8 2019 12:03:56.414 CST: htsp_process_event: [2/19, FXSLS_WAIT_OFFH OOK, E_HTSP_VOICE_CUT_THROUGH]fxsls_waitoff_voice
008430: Feb 8 2019 12:03:56.414 CST: //186/xxxxxxxxxxxx/CCAPI/ccCallFeature:
Feature Type=24, Call Id=186htsp_call_feature:feature 24
008431: Feb 8 2019 12:03:56.414 CST: [2/19] htsp_set_caller_id_tx_time Caller I D:FSK_DURING_RING
008432: Feb 8 2019 12:03:56.418 CST: htsp_process_event: [2/19, FXSLS_WAIT_OFFH OOK, E_HTSP_CALLERID_RINGING]fxsls_onhook_callerid
008433: Feb 8 2019 12:03:56.418 CST: [2/19] c2400_ring_gen: ring1_cadence_on=25 0 ring1_cadence_off=500 ring2_cadence_on=0 ring2_cadence_off=0 ring3_cadence_on= 0 ring3_cadence_off=0 ring4_cadence_on=0 ring4_cadence_off=0 ring5_cadence_on=0 ring5_cadence_off=0 ring6_cadence_on=0 ring6_cadence_off=0
008434: Feb 8 2019 12:03:56.418 CST: [2/19] c2400_set_sig_state: ABCD=0, timest amp=0, sys_time=86220472htsp_alert
008435: Feb 8 2019 12:03:56.418 CST: //186/xxxxxxxxxxxx/CCAPI/cc_api_call_alert :
Interface=0x63146298, Progress Indication=INBAND(8), Signal Indication=SIGNAL RINGBACK(1)
008436: Feb 8 2019 12:03:56.418 CST: //186/xxxxxxxxxxxx/CCAPI/cc_api_call_alert :
Call Entry(Retry Count=0, Responsed=TRUE)
008437: Feb 8 2019 12:03:56.482 CST: [2/19] do_ring_cadence IDLE->ON (2000)
008438: Feb 8 2019 12:03:58.482 CST: [2/19] do_ring_cadence ON->OFF (4000)
008439: Feb 8 2019 12:03:59.842 CST: htsp_timer_stop3
008440: Feb 8 2019 12:03:59.846 CST: //186/xxxxxxxxxxxx/CCAPI/cc_api_voice_mode _event:
Call Id=186
008441: Feb 8 2019 12:03:59.846 CST: //186/xxxxxxxxxxxx/CCAPI/cc_api_voice_mode _event:
008442: Feb 8 2019 12:03:59.846 CST: htsp_process_event: [2/19, FXSLS_WAIT_OFFH OOK, E_HTSP_VOICE_CUT_THROUGH]fxsls_waitoff_voice
008443: Feb 8 2019 12:04:02.482 CST: [2/19] do_ring_cadence OFF->ON (2000)
008444: Feb 8 2019 12:04:04.482 CST: [2/19] do_ring_cadence ON->OFF (4000)
HQVG224#sh log
filtering disabled
Buffer logging: level debugging, 17482 messages logged, xml disabled,
filtering disabled
filtering disabled
008393: Feb 8 2019 12:03:56.386 CST: //-1/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivate:
Subsriber Type Str=, FinalDestinationFlag=FALSE, Outgoing Dial-peer=0, Call Count On=FALSE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=A0000000027eb3f6000000F5)
008394: Feb 8 2019 12:03:56.390 CST: //186/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivate:
Context=0x635533B8
008396: Feb 8 2019 12:03:56.390 CST: //-1/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivate:
Subsriber Type Str=, FinalDestinationFlag=FALSE, Outgoing Dial-peer=0, Call Count On=TRUE,
008397: Feb 8 2019 12:03:56.390 CST: //187/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivate:
Context=0x63552EE8
008400: Feb 8 2019 12:03:56.394 CST: //187/xxxxxxxxxxxx/CCAPI/cc_api_call_connected:
Connection Handle=0
008401: Feb 8 2019 12:03:56.394 CST: //187/xxxxxxxxxxxx/CCAPI/cc_api_call_connected:
008402: Feb 8 2019 12:03:56.398 CST: htsp_process_event: [2/19, FXSLS_ONHOOK, E_HTSP_SETUP_REQ]fxsls_onhook_setup
008403: Feb 8 2019 12:03:56.398 CST: //186/xxxxxxxxxxxx/CCAPI/cc_api_call_proceeding:
008405: Feb 8 2019 12:03:56.398 CST: //186/xxxxxxxxxxxx/CCAPI/ccCallReportDigits:
008406: Feb 8 2019 12:03:56.398 CST: //186/xxxxxxxxxxxx/CCAPI/ccCallReportDigits:
008407: Feb 8 2019 12:03:56.402 CST: //186/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
(vdbPtr=0x63146298, callID=0xBA, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
008408: Feb 8 2019 12:03:56.402 CST: //186/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
008409: Feb 8 2019 12:03:56.402 CST: //186/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
008410: Feb 8 2019 12:03:56.402 CST: //186/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
008411: Feb 8 2019 12:03:56.402 CST: //186/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
008413: Feb 8 2019 12:03:56.402 CST: //186/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
008414: Feb 8 2019 12:03:56.402 CST: //187/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
008415: Feb 8 2019 12:03:56.402 CST: //186/xxxxxxxxxxxx/CCAPI/cc_generic_bridge_done:
008416: Feb 8 2019 12:03:56.402 CST: //186/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
008417: Feb 8 2019 12:03:56.402 CST: //187/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
Destination Interface=0x62EFE2C8, Destination Call Id=187, Source Call Id=186,
Destination Interface=0x63146298, Destination Call Id=186, Source Call Id=187,
008424: Feb 8 2019 12:03:56.406 CST: //186/xxxxxxxxxxxx/CCAPI/cc_process_notify_bridge_done:
008425: Feb 8 2019 12:03:56.410 CST: //186/xxxxxxxxxxxx/CCAPI/cc_api_call_modify_done:
008426: Feb 8 2019 12:03:56.410 CST: htsp_process_event: [2/19, FXSLS_WAIT_OFFHOOK, E_HTSP_VOICE_CUT_THROUGH]fxsls_waitoff_voice
008427: Feb 8 2019 12:03:56.414 CST: //186/xxxxxxxxxxxx/CCAPI/cc_api_voice_mode_event:
Call Id=186
008428: Feb 8 2019 12:03:56.414 CST: //186/xxxxxxxxxxxx/CCAPI/cc_api_voice_mode_event:
008429: Feb 8 2019 12:03:56.414 CST: htsp_process_event: [2/19, FXSLS_WAIT_OFFHOOK, E_HTSP_VOICE_CUT_THROUGH]fxsls_waitoff_voice
008431: Feb 8 2019 12:03:56.414 CST: [2/19] htsp_set_caller_id_tx_time Caller ID:FSK_DURING_RING
008432: Feb 8 2019 12:03:56.418 CST: htsp_process_event: [2/19, FXSLS_WAIT_OFFHOOK, E_HTSP_CALLERID_RINGING]fxsls_onhook_callerid
008433: Feb 8 2019 12:03:56.418 CST: [2/19] c2400_ring_gen: ring1_cadence_on=250 ring1_cadence_off=500 ring2_cadence_on=0 ring2_cadence_off=0 ring3_cadence_on=0 ring3_cadence_off=0 ring4_cadence_on=0 ring4_cadence_off=0 ring5_cadence_on=0 ring5_cadence_off=0 ring6_cadence_on=0 ring6_cadence_off=0
008434: Feb 8 2019 12:03:56.418 CST: [2/19] c2400_set_sig_state: ABCD=0, timestamp=0, sys_time=86220472htsp_alert
008435: Feb 8 2019 12:03:56.418 CST: //186/xxxxxxxxxxxx/CCAPI/cc_api_call_alert:
008436: Feb 8 2019 12:03:56.418 CST: //186/xxxxxxxxxxxx/CCAPI/cc_api_call_alert:
008440: Feb 8 2019 12:03:59.846 CST: //186/xxxxxxxxxxxx/CCAPI/cc_api_voice_mode_event:
Call Id=186
008441: Feb 8 2019 12:03:59.846 CST: //186/xxxxxxxxxxxx/CCAPI/cc_api_voice_mode_event:
008442: Feb 8 2019 12:03:59.846 CST: htsp_process_event: [2/19, FXSLS_WAIT_OFFHOOK, E_HTSP_VOICE_CUT_THROUGH]fxsls_waitoff_voice
008445: Feb 8 2019 12:04:06.402 CST: //186/xxxxxxxxxxxx/CCAPI/cc_handle_inter_digit_timer:
Generate inter-digit timeout CC_EV_CALL_DIGIT_END event
008446: Feb 8 2019 12:04:08.482 CST: [2/19] do_ring_cadence OFF->ON (2000)
008447: Feb 8 2019 12:04:10.482 CST: [2/19] do_ring_cadence ON->OFF (4000)
008448: Feb 8 2019 12:04:14.483 CST: [2/19] do_ring_cadence OFF->ON (2000)
008449: Feb 8 2019 12:04:16.483 CST: [2/19] do_ring_cadence ON->OFF (4000)
008450: Feb 8 2019 12:04:20.483 CST: [2/19] do_ring_cadence OFF->ON (2000)
008451: Feb 8 2019 12:04:22.483 CST: [2/19] do_ring_cadence ON->OFF (4000)
008452: Feb 8 2019 12:04:26.483 CST: [2/19] do_ring_cadence OFF->ON (2000)
008453: Feb 8 2019 12:04:28.483 CST: [2/19] do_ring_cadence ON->OFF (4000)
008454: Feb 8 2019 12:04:32.483 CST: [2/19] do_ring_cadence OFF->ON (2000)
008455: Feb 8 2019 12:04:34.483 CST: [2/19] do_ring_cadence ON->OFF (4000)
008456: Feb 8 2019 12:04:38.483 CST: [2/19] do_ring_cadence OFF->ON (2000)
008457: Feb 8 2019 12:04:40.483 CST: [2/19] do_ring_cadence ON->OFF (4000)
HQVG224#
HQVG224#sh voice call status
CallID CID ccVdb Port DSP/Ch Called # Codec Dial-peers
0xBA 0 0x63146298 2/19 0/1:1 * g711ulaw 0/99920
1 active call found
02-08-2019 10:17 AM
here is the config for the port:
HQVG224#show voice port 2/19
Foreign Exchange Station 2/19 Slot is 2, Port is 19
Type of VoicePort is FXS
Operation State is DORMANT
Administrative State is UP
The Last Interface Down Failure Cause is Administrative Shutdown
Description is not set
Noise Regeneration is enabled
Non Linear Processing is enabled
Non Linear Mute is disabled
Non Linear Threshold is -21 dB
Music On Hold Threshold is Set to -38 dBm
In Gain is Set to 0 dB
Out Attenuation is Set to 0 dB
Echo Cancellation is enabled
Echo Cancellation NLP mute is disabled
Echo Cancellation NLP threshold is -21 dB
Echo Cancel Coverage is set to 64 ms
Echo Cancel worst case ERL is set to 6 dB
Playout-delay Mode is set to adaptive
Playout-delay Nominal is set to 60 ms
Playout-delay Maximum is set to 250 ms
Playout-delay Minimum mode is set to default, value 40 ms
Playout-delay Fax is set to 300 ms
Connection Mode is normal
Connection Number is not set
Initial Time Out is set to 10 s
Interdigit Time Out is set to 10 s
Call Disconnect Time Out is set to 60 s
Supervisory Disconnect Time Out is set to 750 ms
Ringing Time Out is set to 180 s
Wait Release Time Out is set to 30 s
Companding Type is u-law
Region Tone is set for US
Analog Info Follows:
Currently processing none
Maintenance Mode Set to None (not in mtc mode)
Number of signaling protocol errors are 0
Impedance is set to 600r Ohm
Analog interface A-D gain offset = -3.0 dB
Analog interface D-A gain offset = -3.0 dB
FXS idle voltage set to high
alt-battery-feed set to feed1
Ring DC offset set to 0 volt
Station name None, Station number None
Translation profile (Incoming):
Translation profile (Outgoing):
Voice card specific Info Follows:
Signal Type is loopStart
Ring Frequency is 25 Hz
Hook Status is On Hook
Ring Active Status is inactive
02-08-2019 10:20 AM
and dial peer config:
HQVG224#show dial-peer voice 99920
VoiceEncapPeer99920
peer type = voice, system default peer = FALSE, information type = voice ,
description = `',
tag = 99920, destination-pattern = `',
answer-address = `', preference=0,
CLID Restriction = None
CLID Network Number = `'
CLID Second Number sent
CLID Override RDNIS = disabled,
source carrier-id = `', target carrier-id = `',
source trunk-group-label = `', target trunk-group-label = `',
numbering Type = `unknown'
group = 99920, Admin state is up, Operation state is up,
Outbound state is down,
incoming called-number = `', connections/maximum = 0/unlimited,
DTMF Relay = disabled,
URI classes:
Destination =
huntstop = disabled,
in bound application associated: 'mgcpapp'
out bound application associated: ''
dnis-map =
permission :both
incoming COR list:maximum capability
outgoing COR list:minimum requirement
incoming call blocking:
translation-profile = `'
disconnect-cause = `no-service'
advertise 0x40 capacity_update_timer 25 addrFamily 0 oldAddrFamily 0
type = pots, prefix = `',
forward-digits default
session-target = `', voice-port = `2/0',
direct-inward-dial = disabled,
digit_strip = enabled,
register E.164 number with H323 GK and/or SIP Registrar = TRUE
fax rate = system, payload size = 20 bytes
supported-language = ''
Time elapsed since last clearing of voice call statistics never
Connect Time = 0, Charged Units = 0,
Successful Calls = 0, Failed Calls = 0, Incomplete Calls = 0
Accepted Calls = 0, Refused Calls = 0,
Last Disconnect Cause is "",
Last Disconnect Text is "",
Last Setup Time = 0.
Last Disconnect Time = 0.
