NVCONFIG
This is the start up config file which resides in the NVRAM
I think your NVRAM is corrupt
I hope you have kept a copy of your config file off the box as I think you need to replace the VG224.
You could try
enable mode
dir nvram:
Look to see if your config file is present.
Try booting to box into ROMMON
change config reg to 0x2142
reset
Then box may come up as default.
enable mode
show start
try erase startup
then change conf reg back to 0x2102
reload
and then reconfigure
Alex
Alex.
Please rate useful posts.
