07-12-2007 05:31 AM - edited 03-14-2019 10:31 PM
I have vg224 and ports randomly go to some strange state. You can see this state trough this output:
VG-224-6#show voice call summary
PORT CODEC VAD VTSP STATE VPM STATE
2/0 g711ulaw n S_SETUP_REQ_PROC FXSLS_ONHOOK
2/1 g711ulaw n S_SETUP_REQ_PROC FXSLS_ONHOOK
2/2 g711ulaw n S_SETUP_REQ_PROC FXSLS_ONHOOK
2/3 - - - FXSLS_ONHOOK
2/4 - - - FXSLS_ONHOOK
2/5 - - - FXSLS_ONHOOK
2/6 - - - FXSLS_ONHOOK
2/7 - - - FXSLS_ONHOOK
2/8 g711ulaw n S_SETUP_REQ_PROC FXSLS_ONHOOK
2/9 - - - FXSLS_ONHOOK
2/10 - - - FXSLS_ONHOOK
2/11 g711ulaw n S_SETUP_REQ_PROC FXSLS_ONHOOK
2/12 - - - FXSLS_ONHOOK
2/13 - - - FXSLS_ONHOOK
2/14 - - - FXSLS_ONHOOK
2/15 - - - FXSLS_ONHOOK
2/16 - - - FXSLS_ONHOOK
2/17 - - - FXSLS_ONHOOK
2/18 - - - FXSLS_ONHOOK
2/19 - - - FXSLS_ONHOOK
2/20 g711ulaw n S_SETUP_REQ_PROC FXSLS_ONHOOK
2/21 - - - FXSLS_ONHOOK
2/22 - - - FXSLS_ONHOOK
2/23 - - - FXSLS_ONHOOK
Phones conected to ports where you see the S_SETUP_REQ_PROC vtsp state don't work. If we reload the router the ports are OK for some time and than radomly goes to that state again. So we must move phones and numbers to another physical ports. Any sugestions?
07-18-2007 12:27 PM
The IOS that seems to resolve this is IOS 12.4(7a).
Also, as a workaround, have you tried configured one of the VG224s for MGCP instead of SCCP to see if the issue persists?
07-18-2007 10:36 PM
Yes i changed the configuration from SCCP to MGCP and that solved the problem. But i want to keep SCCP, any suggestions. The IOS version on VG224 is 12.4(16).
08-02-2007 08:39 PM
Hi, Can you please send me your working configuration of VG224, 'cause I'm having same kind of issues with my box. I've also changed the IOS to 12.4(16) and i'm using MGCP.
email: ahmer74@hotmail.com
Thanks in advance
