vg224 will not registered
dtom
We used the Batch Administration to add several vg224's.  The first few registered fine.  But the last few wont register.
Here are some Gateway Details:
Gateway - SKIGW23335F3FBA
Protocol - SCCP
Port 17 Status - none
Port 17 IPv4 Address - none
Here is the show sccp on one of the vg224's that wont register:
Alg_Phone Oper State: ACTIVE - Cause Code: NONE
Active Call Manager: 10.223.250.14, Port Number: 2000
TCP Link Status: CONNECTED, Device Name: AN23335F3FBA417
Reported Max Streams: 1, Reported Max OOS Streams: 0
Supported Codec: g711ulaw, Maximum Packetization Period: 20
Supported Codec: g711alaw, Maximum Packetization Period: 20
Supported Codec: g729r8, Maximum Packetization Period: 220
Supported Codec: g729ar8, Maximum Packetization Period: 220
Supported Codec: g729br8, Maximum Packetization Period: 220
Any thoughts?
Chris Deren
Make sure that the device pool assigned to the ports matches the SCCP configuration and same CUCM servers are referenced on both sides.
pankajbhosale
Hey,
Not sure but can you please check license part.
It seems above ver 8.x you need license per analog station, hooked to vg.
Bye
