03-18-2016 01:18 PM - edited 03-17-2019 06:18 AM
When going off-hook on an analog phone attached to a VG310 or VG350 FXS port, I receive inside dial tone. I dial 9 and continue to hear the same inside dial tone (frequency). I can continue to dial the outgoing number and the call will go through. I have verified that the FXS is showing the 2 different dial tones through DEBUG SCCP ALL;
(Go Off-Hook)
018904: Mar 18 16:08:01.040: StartToneMsg Info:
tone: 33, direction: 0, line: 1, call_ref: 77061090
018905: Mar 18 16:08:01.040: xapp_xlate_cm_tone_to_sym_tone:InsideDialTone -
(Dial 9)
022338: Mar 18 16:10:30.063: xapp_xlate_cm_tone_to_sym_tone:OutsideDialTone --
With all of our SIP phones, 8841 and 8861, we receive a different tone for outside dial tone when 9 is pressed. Is it possible to get the VG310 and or VG350 to give a different tone for outside dial tone?
03-18-2016 02:05 PM
which protocol dose your VGs works on ?? (Sccp, Sip, MGCP )
03-19-2016 09:17 AM
Our VG310/350 are using SCCP to CUCM 10.52
03-19-2016 10:56 AM
Then outside tone for outside calls must be configured inside your cucm, also it must be enabled by default.
