Bookmark
Subscribe
2788
Vg310 configuration example
a.trueland1
I am new to VG310 hardware.  I have experience with CME/SIP provider services.  I was asked to setup a VG310 to a SIP provider to support faxing.  Are there any available configuration examples for this?  Is the programming similar to a CME enabled router?
AT
Manish Gogna
You can reference the following as per the topology
http://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unified-border-element/115742-fax-modem-call-flows-00.html
Manish
Thank You.  Do the dial-peers program on the Vg310 just like on a voice enabled router ? I will be using SIP dial-peers to a SIP provider.
