10-07-2015 07:01 PM - edited 03-17-2019 04:31 AM
Router#sh run | s stcapp
stcapp ccm-group 1
stcapp
stcapp supplementary-services
port 0/3/1
fallback-dn 101
service stcapp
Router#
Router#sh run | s voice-card
voice-card 0
dsp services dspfarm
Router#
Router#sh run | s interface FastEthernet0/0
ip address 10.2.1.4 255.255.255.0
duplex auto
speed auto
Router#
Router#sh run | s voice-port
voice-port 0/3/0
voice-port 0/3/1
timeouts ringing infinity
voice-port 0/3/2
voice-port 0/3/3
Router#
Router#sh run | s sccp
sccp local FastEthernet0/0
sccp ccm 10.2.1.4 identifier 10 version 7.0
sccp
sccp ccm group 1
associate ccm 10 priority 1
Router#
Router#sh run | s dial-peer
dial-peer voice 106 pots
service stcapp
port 0/3/1
no sip-register
dial-peer voice 107 pots
destination-pattern 113
port 0/3/3
Router#
Router#sh run | s tele
telephony-service
authentication credential admin Atomic1
max-ephones 5
max-dn 21
ip source-address 10.2.1.4 port 2000
url authentication http://10.2.1.4/CCMCIP/authenticate.asp
time-zone 48
date-format dd-mm-yy
max-conferences 4 gain -6
web admin system name admin password Atomic1
transfer-system full-consult
create cnf-files version-stamp Jan 01 2002 00:00:00
Router#
Router#sh run | s ephone
max-ephones 5
ephone-dn 1
number 101 no-reg primary
description FXS 0/3/1
name FXS 0/3/1
ephone-dn 2
number 102 no-reg primary
description SoftPhone
name SoftPhone
ephone 1
device-security-mode none
mac-address E7A4.CE78.2181
max-calls-per-button 2
type anl
button 1:1
ephone 2
description IP Communicator Test Phone
mac-address 001C.421E.9E5A
type CIPC
Here are some pertinent show commands used so far when troubleshooting…
These commands were used before and whilst placing a call from the soft phone…
All looks good as far as I can tell, just the handset doesn’t ring neither can I answer the call from the handset (I’ve used multiple handsets and tested them using a PSTN line so I know they’re good - I’m in Australia btw)
STCAPP extension testing… (ext 101)
Router#sh voice port sum
IN OUT
PORT CH SIG-TYPE ADMIN OPER STATUS STATUS EC
0/3/0 -- fxs-ls up dorm on-hook idle y
0/3/1 -- fxs-ls up dorm on-hook idle y
0/3/2 -- fxs-ls up dorm on-hook idle y
0/3/3 -- fxs-ls up dorm on-hook idle y
50/0/1 1 efxs up dorm on-hook idle y
50/0/2 1 efxs up dorm on-hook idle y
PWR FAILOVER PORT PSTN FAILOVER PORT
IN OUT
0/3/1 -- fxs-ls up up on-hook ringing y
50/0/1 1 efxs up up on-hook ringing y
Router#show voice call sum
Router#show voice call summary
PORT CODEC VAD VTSP STATE VPM STATE
0/3/0 - - - FXSLS_ONHOOK
0/3/1 - - - FXSLS_ONHOOK
0/3/2 - - - FXSLS_ONHOOK
0/3/3 - - - FXSLS_ONHOOK
50/0/1 .1 - - - EFXS_ONHOOK
50/0/2 .1 - - - EFXS_ONHOOK
0/3/1 g711ulaw n S_SETUP_REQ_PROC FXSLS_WAIT_OFFHOOK
50/0/1 .1 g711ulaw n S_SETUP_REQ_PROC EFXS_WAIT_OFFHOOK
Traditional dial-peer with destination-pattern testing (ext 113)…
IN OUT
IN OUT
0/3/3 -- fxs-ls up up on-hook ringing y
50/0/2 1 efxs up up off-hook idle y
0/3/3 g711ulaw n S_SETUP_REQ_PROC FXSLS_WAIT_OFFHOOK
50/0/2 .1 g711ulaw n S_PROCEEDING EFXS_OFFHOOK
Router#
Additional...
sh voice port
Foreign Exchange Station 0/3/0 Slot is 0, Sub-unit is 3, Port is 0
Type of VoicePort is FXS VIC-4DID
Operation State is DORMANT
Administrative State is UP
No Interface Down Failure
Description is not set
Noise Regeneration is enabled
Non Linear Processing is enabled
Non Linear Mute is disabled
Non Linear Threshold is -21 dB
Music On Hold Threshold is Set to -38 dBm
In Gain is Set to 0 dB
Out Attenuation is Set to 3 dB
Echo Cancellation is enabled
Echo Cancellation NLP mute is disabled
Echo Cancellation NLP threshold is -21 dB
Echo Cancel Coverage is set to 128 ms
Echo Cancel worst case ERL is set to 6 dB
Playout-delay Mode is set to adaptive
Playout-delay Nominal is set to 60 ms
Playout-delay Maximum is set to 1000 ms
Playout-delay Minimum mode is set to default, value 40 ms
Playout-delay Fax is set to 300 ms
Connection Mode is normal
Connection Number is not set
Initial Time Out is set to 15 s
Interdigit Time Out is set to 10 s
Call Disconnect Time Out is set to 60 s
Supervisory Disconnect Time Out is set to 750 ms
Ringing Time Out is set to 180 s
Wait Release Time Out is set to 30 s
Companding Type is u-law
Region Tone is set for US
Analog Info Follows:
Currently processing none
Maintenance Mode Set to None (not in mtc mode)
Number of signaling protocol errors are 0
Impedance is set to 600r Ohm
Station name None, Station number None
Translation profile (Incoming):
Translation profile (Outgoing):
lpcor (Incoming):
lpcor (Outgoing):
Voice card specific Info Follows:
Signal Type is loopStart
Ring Frequency is 25 Hz
Hook Status is On Hook
Ring Active Status is inactive
Ring Ground Status is inactive
Tip Ground Status is active
Digit Duration Timing is set to 100 ms
InterDigit Duration Timing is set to 100 ms
Hookflash-in Timing is set to max=1000 ms, min=150 ms
Hookflash-out Timing is set to 400 ms
No disconnect acknowledge
Ring Cadence is defined by CPTone Selection
Ring Cadence are [20 40] * 100 msec
Ringer Equivalence Number is set to 1
Foreign Exchange Station 0/3/1 Slot is 0, Sub-unit is 3, Port is 1
Ringing Time Out is set to infinity
lpcor (Incoming):
lpcor (Outgoing):
Tip Ground Status is inactive
Foreign Exchange Station 0/3/2 Slot is 0, Sub-unit is 3, Port is 2
lpcor (Incoming):
lpcor (Outgoing):
Foreign Exchange Station 0/3/3 Slot is 0, Sub-unit is 3, Port is 3
lpcor (Incoming):
lpcor (Outgoing):
Can anyone suggest any further testing or confirm if this looks like a hardware/config issue?
Rhodri
10-07-2015 08:47 PM
This area is dedicated to Video Over IP questions, I suggest you move this to a relevant area.
