12-03-2015 11:22 AM - edited 03-17-2019 05:06 AM
Forum,
I have a customer with a Cisco 2911 that will replace a Cisco 2821. The show version of the Cisco 2911 (last part) is as follows
License Info:
License UDI:
Device# PID SN
*1 CISCO2901/K9 FJC1943A1EU
Technology Package License Information for Module:'c2900'
Technology Technology-package Technology-package
Current Type Next reboot
ipbase ipbasek9 Permanent ipbasek9
security None None None
uc uck9 Permanent uck9
data None None None
NtwkEss None None None
CollabPro None None None
My show inventory is the following
NAME: "CISCO2901/K9", DESCR: "CISCO2901/K9 chassis, Hw Serial#: FJC1943A1EU, Hw Revision: 1.0"
PID: CISCO2901/K9 , VID: V06 , SN: FJC1943A1EU
NAME: "WAN Interface Card - HWIC CSU/DSU on Slot 0 SubSlot 0", DESCR: "WAN Interface Card - HWIC CSU/DSU"
PID: HWIC-1DSU-T1 , VID: V02 , SN: FOC19311TS2
NAME: "PVDM3 DSP DIMM with 16 Channels on Slot 0 SubSlot 4", DESCR: "PVDM3 DSP DIMM with 16 Channels"
PID: PVDM3-16 , VID: V01 , SN: FOC193804W3
NAME: "PVDM3 DSP DIMM with 16 Channels on Slot 0 SubSlot 5", DESCR: "PVDM3 DSP DIMM with 16 Channels"
PID: PVDM3-16 , VID: V01 , SN: FOC194191G8
NAME: "C1941/C2901 AC Power Supply", DESCR: "C1941/C2901 AC Power Supply"
PID: PWR-1941-2901-AC , VID: , SN:
so not a DSP issue...documentation shows for the Cisco 2911 that the VIC3-2FXS/DID is supported. Is there a global command to activate? Very strange...
12-03-2015 01:29 PM
is there any light glowing on the VIC3-2FXS/DID? orange/green? also try to change the slot of the DID card.
Br,
Nadeem
12-04-2015 05:17 AM
Nadeem,
Yes amber light was glowing.
12-04-2015 05:19 AM
Nadeem, also...the VIC3 was installed in slot 3...I did advise the customer to move to slot 0 and see if the issue is still the same. Still waiting for answer from customer. Will advise...thx.
12-04-2015 06:43 AM
Hi, after you installed the card did you reboot ? The cards are not hot swappable so if you havent rebooted since its been inserted this will need to be done.
Thanks, Carl Ratcliffe
Preston-Lancashire-England
