Video Conference
MuhammadSaad_2
Am facing issue with video conference. I have 4 9971 IP Phones and 18 8941 IP Phones. All are working properly but when we do video conference call.
It change to audio and no more video sharing between 3 people.
Also if some one call through cisco jabber( IP Phone ), video not work point to point.
Kindly urgently advice how to resolve the issue.
Thank You
7 Replies 7
Jaime Valencia
Do you have a video CFB???
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Am just using CUCM 9 ad hoc conference bridge.
Then there's no surprise there, if you don't have a video CFB you cannot expect to have video conferences.
Only some TP endpoints can do that on their own.
java
java
Their is any possible way to achive the video conference without using any MCU.
You can also use PVDM3 for basic video conference, other that that, no, theres no other option just using CUCM
java
I have PVDM3-16U32, which am using for E1 line .
controller E1 0/0/0
pri-group timeslots 1-20
So as per the configuration i have 11 channel. Kindly tell how should i configure pvdm for video conference..
Search CCO for PVDM3 + video conference to find the guides and all the necessary info
java
