01-26-2012 08:41 PM - edited 03-16-2019 09:14 AM
I try to configure viewmail 8.6.5 with outlook 2010 on a windows 7 computer. We have unity 7 and exchange 2007. I enter all the information in the viewmail setup but when I click test settings it says unable to find the voice mail server. The unity server name I entered is correct I can also ping it from my computer. Any suggestions.
Thanks.
Solved! Go to Solution.
03-09-2012 08:08 AM
Hello All,
My problem was that I had my not applied my HA license on my CUC SUB. One applied things worked properly.
Regards. Inder.
04-18-2012 03:56 PM
ViewMail 8.6.5 does work with Outlook 2010. I have it installed on my Windows 7 computer with Outlook 2010. However you have to instal VMWS7.0(2) in order to get it to work with Unity 7. The only problem is that it won't play message from shared mailboxes to the phone, plays fine to the speakers, and plays your mailbox fine to either the phone or speakers.
