Voice Bundle Routers vs UC Bundle Routers
anis_cisco
Hello all,
I am techinal engineer, but i need to make BoQ for 3945 CME-SRST for one of our client.
In Cisco Commerce Workspace i can see there are two types of 3945 routers are available for CME SRST
1- C3945-CME-SRST/K9 = 3945 Voice Bundle w/PVDM3-64,FL-CME-SRST-25,UC Lic,FL-CUBE25
2- C3945-CMESRSTK9-RF = 3945 UC Bun PVDM3-64, FL-CME-SRST-25, UC Lic PAK REFURBISHED
What is the difference between both, a part from this that option 2 is refurbished router, is there any other differ between both products ?
My client has 120 Users on site & i need to make BoQ that cover 120 users.
Also what is the difference between C3945 & C3945E product ?
Dragan Ilic
Level 4
Level 4
Basically these two bundles are same - UC/Voice bundles...exept that option one have free CUBE licenses which Cisco from near past included in voice bundles - because of obvious SIP  popularity. So if I'm on your place - I would go with option 1.
3945 vs 3945E - maybe this will help:
https://supportforums.cisco.com/sites/default/files/legacy/0/5/3/78350-white_paper_c11_595485.pdf
Offcourse you can suspect which platform is more powerfull smiley
HTH,
Dragan
HTH,
Dragan
Dragan Ilic
Level 4
Level 4
HTH,
Dragan
HTH,
Dragan
Perfect answer.
Cheers smiley
