Voice Encryption for Jabber & 8800
ShankarP
Hi experts, there is a need to encrypt voice traffic and I have moved CUCM to mixed mode and assigned secured profile for Jabber & Hard phones. Would like to check on below items,
- the gateway is currently using mgcp, do I need to reconfigure for SIP TLS?
- how does Jabber & 8800 RENEW their identify certs ? Anything needs to configured?
Many Thanks
Jonathan Schulenberg
1. You should use SIP TLS instead. Continuing to use MGCP would require the use of IPSec between the OS of the CUCM VMs (ie OS Administration) and the IOS router.
2. They don’t. Welcome to one of many limitations of mixed mode. You must manually initiate the CAPF renewal operation from CUCM Admin, either individually per-device or in bulk using BAT.
Thanks Jonathan, where can i adjust the client cert validity period ? Thanks
The CAPF Service Parameter "Duration Of Certificate Validity (in days)" has a default value of 1825 or five years. It would be fairly unusual to generate a certificate for longer than that. The longer the RSA keys are in use the greater theoretical chance they can be compromised.
