01-27-2017 07:32 AM - edited 03-17-2019 09:19 AM
I have a customer that is due to migrate their CUCM from 9.1.1 to 11.5 and has 2 x 2900 voice gateways running 15.2-4m3 ios. I have been looking for a compatibility or testbed guide but without success to see if we will need to upgrade the IOS also. The nearest I got was for 10.5.
Could anyone please point me in the right direction.
Many thanks, John.
Solved! Go to Solution.
01-27-2017 07:42 AM
See here
http://www.cisco.com/c/dam/en/us/td/docs/voice_ip_comm/uc_system/unified/communications/system/Compatibility/CSR-Compatibility-Matrix-InteractiveHTML.html
01-27-2017 07:43 AM
Hi John,
Please refer the following link:
15.5(2)T1 is the minimum and 15.6(3)M is the recommended for 2900 routers.
Please rate and mark correct if helpful.
Hitesh
01-27-2017 07:42 AM
See here
01-27-2017 08:49 AM
many thanks
01-27-2017 07:43 AM
Hi John,
Hitesh
01-27-2017 08:48 AM
Many thanks.
