01-29-2017 10:16 PM - edited 03-17-2019 09:20 AM
Hi All,
I would like to validate if the disconnection cause are coming from Telco or not. Kindly see below ccapi and vpm signal logs for outgoing calls.
Telco said that the line has a dial tone however we are still receiving cause code 34 and 47 and no logs were being seen for the incoming call during debugging.
debug voip ccapi inout
Jan 30 05:19:38.395: //-1/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivate:
Interface=0x3D30FCC8, Interface Type=6, Destination=4416133, Mode=0x9,
Call Params(Calling Number=,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=4416133(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
Subscriber Type Str=, FinalDestinationFlag=FALSE, Outgoing Dial-peer=0, Call Count On=FALSE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=A000000003e35655000000F5)
Jan 30 05:19:38.395: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Jan 30 05:19:38.395: :cc_get_feature_vsa malloc success
Jan 30 05:19:38.395: cc_get_feature_vsa count is 1
Jan 30 05:19:38.395: :FEATURE_VSA attributes are: feature_name:0,feature_time:1007125632,feature_id:2481
Jan 30 05:19:38.395: //2481/87BB6CB482D6/CCAPI/ccIFCallSetupRequestPrivate:
SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
Jan 30 05:19:38.395: //2481/87BB6CB482D6/CCAPI/ccCallSetContext:
Context=0x3E5EFEB8
Interface=0x2253C6B4, Interface Type=9, Destination=0.0.0.0, Mode=0x9,
Called Number=(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
Subscriber Type Str=, FinalDestinationFlag=FALSE, Outgoing Dial-peer=0, Call Count On=TRUE,
Jan 30 05:19:38.395: cc_get_feature_vsa count is 2
Jan 30 05:19:38.395: :FEATURE_VSA attributes are: feature_name:0,feature_time:1007125408,feature_id:2482
Jan 30 05:19:38.395: //2482/87BB6CB482D6/CCAPI/ccIFCallSetupRequestPrivate:
SPI Call Setup Request Is Success; Interface Type=9, FlowMode=1
Jan 30 05:19:38.395: //2482/87BB6CB482D6/CCAPI/ccCallSetContext:
Context=0x3E5EFCA8
Jan 30 05:19:38.399: //2482/87BB6CB482D6/CCAPI/cc_api_call_connected:
Interface=0x2253C6B4, Data Bitmask=0x0, Progress Indication=NULL(0),
Connection Handle=0
Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
Jan 30 05:19:38.399: //2481/87BB6CB482D6/CCAPI/cc_api_call_proceeding:
Interface=0x3D30FCC8, Progress Indication=NULL(0)
Jan 30 05:19:39.651: //2481/87BB6CB482D6/CCAPI/cc_api_call_disconnected:
Cause Value=34, Interface=0x3D30FCC8, Call Id=2481
Call Entry(Responsed=TRUE, Cause Value=34, Retry Count=0)
Jan 30 05:19:39.651: //2482/87BB6CB482D6/CCAPI/ccCallDisconnect:
Cause Value=47, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Cause Value=47, Call Entry(Responsed=TRUE, Cause Value=47)
Jan 30 05:19:39.651: //2481/87BB6CB482D6/CCAPI/ccCallDisconnect:
Cause Value=47, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=34)
Cause Value=34, Call Entry(Responsed=TRUE, Cause Value=34)
Jan 30 05:19:39.651: //2482/87BB6CB482D6/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x2253C6B4, Tag=0x0, Call Id=2482,
Call Entry(Disconnect Cause=47, Voice Class Cause Code=0, Retry Count=0)
Call Disconnect Event Sent
Jan 30 05:19:39.651: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Jan 30 05:19:39.651: :cc_free_feature_vsa freeing 3C078398
Jan 30 05:19:39.651: vsacount in free is 1
Jan 30 05:19:39.651: //2481/87BB6CB482D6/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x3D30FCC8, Tag=0x0, Call Id=2481,
Call Entry(Disconnect Cause=34, Voice Class Cause Code=0, Retry Count=0)
Jan 30 05:19:39.651: :cc_free_feature_vsa freeing 3C078478
Jan 30 05:19:39.651: vsacount in free is 0
Jan 30 05:19:39.707: //-1/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivate:
Interface=0x3D30C8CC, Interface Type=6, Destination=4416133, Mode=0x9,
Jan 30 05:19:39.707: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Jan 30 05:19:39.707: :cc_get_feature_vsa malloc success
Jan 30 05:19:39.707: cc_get_feature_vsa count is 1
Jan 30 05:19:39.707: :FEATURE_VSA attributes are: feature_name:0,feature_time:1007125632,feature_id:2483
Jan 30 05:19:39.707: //2483/88839E8882D7/CCAPI/ccIFCallSetupRequestPrivate:
Jan 30 05:19:39.707: //2483/88839E8882D7/CCAPI/ccCallSetContext:
Context=0x3E5F0018
Jan 30 05:19:39.711: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Jan 30 05:19:39.711: cc_get_feature_vsa count is 2
Jan 30 05:19:39.711: :FEATURE_VSA attributes are: feature_name:0,feature_time:1007125408,feature_id:2484
Jan 30 05:19:39.711: //2484/88839E8882D7/CCAPI/ccIFCallSetupRequestPrivate:
Jan 30 05:19:39.711: //2484/88839E8882D7/CCAPI/ccCallSetContext:
Context=0x3E5EFE08
Jan 30 05:19:39.711: //2484/88839E8882D7/CCAPI/cc_api_call_connected:
Connection Handle=0
Jan 30 05:19:39.711: //2483/88839E8882D7/CCAPI/cc_api_call_proceeding:
Interface=0x3D30C8CC, Progress Indication=NULL(0)
Jan 30 05:19:40.967: //2483/88839E8882D7/CCAPI/cc_api_call_disconnected:
Cause Value=34, Interface=0x3D30C8CC, Call Id=2483
Jan 30 05:19:40.967: //2484/88839E8882D7/CCAPI/ccCallDisconnect:
Jan 30 05:19:40.967: //2483/88839E8882D7/CCAPI/ccCallDisconnect:
Jan 30 05:19:40.967: //2484/88839E8882D7/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x2253C6B4, Tag=0x0, Call Id=2484,
Jan 30 05:19:40.967: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Jan 30 05:19:40.967: :cc_free_feature_vsa freeing 3C078398
Jan 30 05:19:40.967: vsacount in free is 1
Jan 30 05:19:40.967: //2483/88839E8882D7/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x3D30C8CC, Tag=0x0, Call Id=2483,
Jan 30 05:19:40.967: :cc_free_feature_vsa freeing 3C078478
Jan 30 05:19:40.967: vsacount in free is 0
Jan 30 05:19:41.043: //-1/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivate:
Interface=0x3D30E5FC, Interface Type=6, Destination=4416133, Mode=0x9,
Jan 30 05:19:41.043: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Jan 30 05:19:41.043: :cc_get_feature_vsa malloc success
Jan 30 05:19:41.047: cc_get_feature_vsa count is 1
Jan 30 05:19:41.047: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Jan 30 05:19:41.047: :FEATURE_VSA attributes are: feature_name:0,feature_time:1007125632,feature_id:2485
Jan 30 05:19:41.047: //2485/894F7B5182D8/CCAPI/ccIFCallSetupRequestPrivate:
Jan 30 05:19:41.047: //2485/894F7B5182D8/CCAPI/ccCallSetContext:
Context=0x3E5EFF68
Jan 30 05:19:41.047: //-1/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivate:
Jan 30 05:19:41.047: :cc_get_feature_vsa malloc success
Jan 30 05:19:41.047: cc_get_feature_vsa count is 2
Jan 30 05:19:41.047: :FEATURE_VSA attributes are: feature_name:0,feature_time:1007125408,feature_id:2486
Jan 30 05:19:41.047: //2486/894F7B5182D8/CCAPI/ccIFCallSetupRequestPrivate:
Jan 30 05:19:41.047: //2486/894F7B5182D8/CCAPI/ccCallSetContext:
Context=0x3E5EFD58
Jan 30 05:19:41.047: //2486/894F7B5182D8/CCAPI/cc_api_call_connected:
Connection Handle=0
Jan 30 05:19:41.047: //2485/894F7B5182D8/CCAPI/cc_api_call_proceeding:
Interface=0x3D30E5FC, Progress Indication=NULL(0)
Jan 30 05:19:42.303: //2485/894F7B5182D8/CCAPI/cc_api_call_disconnected:
Cause Value=34, Interface=0x3D30E5FC, Call Id=2485
Jan 30 05:19:42.303: //2486/894F7B5182D8/CCAPI/ccCallDisconnect:
Jan 30 05:19:42.303: //2485/894F7B5182D8/CCAPI/ccCallDisconnect:
Jan 30 05:19:42.303: //2486/894F7B5182D8/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x2253C6B4, Tag=0x0, Call Id=2486,
Jan 30 05:19:42.303: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Jan 30 05:19:42.303: :cc_free_feature_vsa freeing 3C078398
Jan 30 05:19:42.303: vsacount in free is 1
Jan 30 05:19:42.303: //2485/894F7B5182D8/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x3D30E5FC, Tag=0x0, Call Id=2485,
Jan 30 05:19:42.303: :cc_free_feature_vsa freeing 3C078478
Debug vpm signal
Jan 30 05:25:43.019: htsp_timer_stop3 htsp_setup_req
Jan 30 05:25:43.019: Orig called num:4416133
Jan 30 05:25:43.019: htsp_process_event: [0/0/2, FXOLS_ONHOOK, E_HTSP_SETUP_REQ]fxols_onhook_setup
Jan 30 05:25:43.019: [0/0/2] set signal state = 0xC timestamp = 0
Jan 30 05:25:43.023: htsp_timer - 1300 msec
Jan 30 05:25:43.275: htsp_process_event: [0/0/2, FXOLS_WAIT_DIAL_TONE, E_DSP_SIG_1100]fxols_power_denial_detected
Jan 30 05:25:43.275: htsp_timer2 - 1000 msec
Jan 30 05:25:43.275: htsp_timer_stop
Jan 30 05:25:44.275: htsp_process_event: [0/0/2, FXOLS_WAIT_DIAL_TONE, E_HTSP_EVENT_TIMER2]fxols_power_den_disc
Jan 30 05:25:44.275: htsp_timer_stop
Jan 30 05:25:44.275: htsp_timer_stop2
Jan 30 05:25:44.275: [0/0/2] set signal state = 0x4 timestamp = 0
Jan 30 05:25:44.275: htsp_process_event: [0/0/2, FXOLS_ONHOOK, E_HTSP_RELEASE_REQ]fxols_onhook_release
Jan 30 05:25:44.335: htsp_timer_stop3 htsp_setup_req
Jan 30 05:25:44.339: Orig called num:4416133
Jan 30 05:25:44.339: htsp_process_event: [0/0/3, FXOLS_ONHOOK, E_HTSP_SETUP_REQ]fxols_onhook_setup
Jan 30 05:25:44.339: [0/0/3] set signal state = 0xC timestamp = 0
Jan 30 05:25:44.339: htsp_timer - 1300 msec
Jan 30 05:25:44.591: htsp_process_event: [0/0/3, FXOLS_WAIT_DIAL_TONE, E_DSP_SIG_1100]fxols_power_denial_detected
Jan 30 05:25:44.591: htsp_timer2 - 1000 msec
Jan 30 05:25:44.591: htsp_timer_stop
Jan 30 05:25:45.591: htsp_process_event: [0/0/3, FXOLS_WAIT_DIAL_TONE, E_HTSP_EVENT_TIMER2]fxols_power_den_disc
Jan 30 05:25:45.591: htsp_timer_stop
Jan 30 05:25:45.591: htsp_timer_stop2
Jan 30 05:25:45.591: [0/0/3] set signal state = 0x4 timestamp = 0
Jan 30 05:25:45.591: htsp_process_event: [0/0/3, FXOLS_ONHOOK, E_HTSP_RELEASE_REQ]fxols_onhook_release
Jan 30 05:25:45.687: htsp_timer_stop3 htsp_setup_req
Jan 30 05:25:45.687: Orig called num:4416133
Jan 30 05:25:45.687: htsp_process_event: [0/0/1, FXOLS_ONHOOK, E_HTSP_SETUP_REQ]fxols_onhook_setup
Jan 30 05:25:45.687: [0/0/1] set signal state = 0xC timestamp = 0
Jan 30 05:25:45.687: htsp_timer - 1300 msec
Jan 30 05:25:45.939: htsp_process_event: [0/0/1, FXOLS_WAIT_DIAL_TONE, E_DSP_SIG_1100]fxols_power_denial_detected
Jan 30 05:25:45.939: htsp_timer2 - 1000 msec
Jan 30 05:25:45.939: htsp_timer_stop
Jan 30 05:25:46.939: htsp_process_event: [0/0/1, FXOLS_WAIT_DIAL_TONE, E_HTSP_EVENT_TIMER2]fxols_power_den_disc
Jan 30 05:25:46.939: htsp_timer_stop
Jan 30 05:25:46.939: htsp_timer_stop2
Jan 30 05:25:46.939: [0/0/1] set signal state = 0x4 timestamp = 0
Jan 30 05:25:46.939: htsp_process_event: [0/0/1, FXOLS_ONHOOK, E_HTSP_RELEASE_REQ]fxols_onhook_release
Appreciate your response.
01-29-2017 11:04 PM
Could be a cabling issue from the service provider, have a check on that too.
Anoop
